Copiers
Problem for Copiers
Generic problem for all Copiers
Panasonic
By CULC on Jan 03, 2008
I need to change the developer and clean up an old Panasonic FP 7117 which is my back up copier. I use it a couple of days every several months. B
Solution #1
posted on Mar 06, 2008
Somewhat Helpful)
Jxxx
Rank: Wiz
Rating: 90%, 40 votes
oppen front cover, look for black handle to the far right hand side, turn that clockwise and it will un lock the dev unit so you can slide it out towards you, empty out old dev completely and replace with new, then you can slide drum unit out the same way there is only 1 thumb screw holding that unit in. give the inside of copier a vacuum out and a wipe with a clean lint free rag,
Was this helpful?
Yes
No
Solution #2
posted on Mar 15, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Turning the handle counter clockwise unlocked the developer unit. I eventually discovered that I had to squeeze two plastic tabs together that were above the collection bottle before I could slide the unit out. It took a long time to empty the unit carefully. Fortunately I have little computer cleaning brushes attached to a long flexible plastic tube I can connect to a regular vacuum which were very useful in cleaning the machine and the unit. I put the new developer in making sure it was spread the whole length of the unit (after removing the plastic cover over the unit. Pushing the handle back in so I could close the cover was a bit tricky. Folding the handle to the left (after trying several times) allowed me to close the front cover so it was flush on the right as well as the left. Before I figured out how to get the cover fully closed, I could run to copier, but got blanks on the copies until I finally had the handle properly seated (folding to the left) so the cover would close completely on the right as well as the left. This is a very messy job, and having covers on the floor as well as a trash can with trash liners is necessary. I went through 3 trash bags not because I filled them up, but to cut down on the mess getting out of control and to minimize the filings/toner from getting into the air.
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
reset power code/instructions needed for the HP 5610 all in one printer when giving the error code... (More)
Answer
texas instrument calculator wont turn on. replaced all batteries.
Answer
I have a Dictaphone 2740 Voice Processor. The problems I am having are: 1. Volume is getting... (More)
Describe your Copiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in Windham, ME
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
