Question about Akai LCT2785TA 27 in. LCD Television
Help me connect my components...
I have this TV, an ONKYO sound system, and a combo DVD/VCR player. TV looks great and sounds great, but when I play a DVD or VCR, I get black bars on top, bottom, and sides, when playing the "wide screen" format of my DVD's. How do I get my DVD's to fill up the screen without stretching the picture? Everything is currenly connected with RCA cables. All components also have the option to use component cables and/or S-Video cables.
Suggestions???
Thanks.
    Sergeant:
  • 264 Answers
On the remote it should say menu it would probably be in the pitcher side set it to 4.3 or 4.5 or so on it is the setting you need ok hope that help
Posted on Jan 03, 2008
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
Ignorance on my part. Elect went out for hours; when came back on, no sound. Has something to do with onkyo and it's something simple. I've been thru this before; always seems to happen beginning of 3...
Hi and welcome to FixYa,
Initially, postback with the model numbers of the cable box, the DVD/VCR combo, the TV and the Onkyo. Additionally describe the plug/cable colors used form what jack of what device to which jacks of the next device.
Offhand, it would appear that the connection is basically output of one device is fed as the input of the following device. That being so, each of the devices (except the cable box) would have to be set for which of its inputs was used.
Good luck and thank you for asking FixYa. Merry Christmas.
Dec 25, 2009 | Onkyo Audio Players & Recorders
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Akai LCT2785TA 27 in. LCD Television Logo
103 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
