Home | Western Digital | 500GB My Book World Edition 500 GB Hard Dri... | I can't transer file siz...
Western Digital 500GB My Book World Edition 500 GB Hard Drive
Problem for Western Digital 500GB My Book World Edition 500 GB Hard...
I can't transer file sizes more than 4 GB...
By ghswlh63 on Nov 02, 2009
I can't transer file sizes more than 4 GB... What I've done to get around this is save my movies in multiple parts to make each file size smaller. Is there something I need to be able to transfer my files to my External Harddrive without it quitting at 4 GB?
Comments:
Nov 05, 2009
- alright well how do I accomplish this?? I completely understand the whole problem but have no idea how to reformat my External HardDrive. Also, I would have to move everything off of that to do this, correct? I am running on Mac OSX 10.4.11 if that is any help, thanks again Weston
Nov 05, 2009
- I am using a MAC, I did some research and using Disk utility I can change the format of my Hard Drive...It is Formatted to Fat32 right now as you said, my options to Reformat it are: Mac OS Extended(Journaled), Mac OS Extended,Mac OS Extended (Case Sensitive, Journaled) Mac OS Extended(Case Sensitive), MS-Dos File System, Unix File System... Would/Should I be better off hooking my External Drive to a Windows computer and reformat it on there and then use it with my Mac or will that not work???
Solution #1
posted on Nov 03, 2009
Not Rated)
jestamac188
Rank: Master
Rating: 86%, 7 votes
You have to change your hard drive from FAT32 to NTFS,because FAT32 limits the size of tranfered file to 4GB.
Comments:
Nov 05, 2009
- Because reformatting your hard drive will wipe it clean ,you need to retrieve any files you need.Another point is it's not so easy to reformat back to FAT32  it's difficult.but It can be done . To format you hard drive. Plug in your hard drive.on your PC go to Start,Right click on computer and select  Manage. Under Storage click on Disk Management.Find your hard drive in the list and Right click on it and select Format. Under File System change the Answer to NTFS and leave the Allocation Unit to Default.Click on Perform Quick Format if you want. ClickOK and confirm your OK with losing all data on the drive and your done.
Nov 05, 2009
- Sorry,I assumed you were using a Windows PC. I can't in all honesty say that"Hooking" your hard drive to a Windows PC will do the job. .Personelly if all else fail that's what I would do,but a new hard drive would  cost around £50.
Was this helpful?
Yes
No
Solution #2
posted on Nov 02, 2009
Not Rated)
57 varieties
Rank: Guru
Rating: 88%, 511 votes
This will be a limitation of file size imposed by your operating system and drive format method. For drives formatted under FAT16 (2Gb) or FAT32 (4Gb - 2 bytes). FAT64 allows up to 16Zb while NTFS and NTFS5 both allow any size up to the actual volume capacity so with a 500Gb drive the max would be 500Gb for 1 file. I would therefore suggest that you retrieve all your stored data on the drive and reformat it with NTFS. Then you can have 1 continuous file instead of lots of 4Gb files.
Was this helpful?
Yes
No
Popular Solutions for Western Digital 500GB My Book
Questions and Unsolved Problems for Western Digital 500GB My Book
Do you recommend Western Digital 500GB My Book World Edition 500 GB Hard Drive?
Answer
Answer
Hello, I have a Western Digital External Hard Drive (My Book) that my PC suddenly won't recognise.... (More)
Answer
win7/ WB5000ME drivers? I cannot access the disk or format it but Vista seems to have no problems?
Answer
For the most part, South America became a collection of independent states between:
Answer
when plugged in the light on the hard drive just flickers on and off instead of a solid blue light... (More)
Answer
Cant connect my 1TB WD my book essential edition to my linksys 610n v1 router
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Western Digital 500GB My Book...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
