You didn't give your model, but on the Epson I have (a PowerLite S1), the projection mode is controlled through the "Settings" menu. This may not be right for your model, but I'd think another Epson would be similar.
On mine, this is how it works:
1) Press "Menu" on the projector (or remote, which will work the same way)
2) Use the "V" (down arrow) to highlight "Setting"
3) Press "Enter" to select the "Setting" menu
4) Press "Enter" to select the "Screen" sub-menu
5) Down-arrow to "Projection" and press "Enter" to select it
6) Use the up- and down-arrows to highlight the arrangement you want from the choices offered:
- "Front": normal use
"Front/Ceiling": image is vertically flipped
"Rear": image is horizontally flipped
"Rear/Ceiling": image is flipped both horizontally and vertically
7) Press "Enter" to select
8) Press "Menu" to exit the menus
I hope this works for you, or at least gives you a starting point. Good luck, and thanks for using Fixya!
