32inch LCD Matsui TV
Hello, I brought the tele and Freeveiw box and using an indoor digital airel with amplifier im getting this low pitch BUZZ noise continuious on and off, at all times comes on for 10 seconds off for 4 seconds, think its comin from the tele, is this a fault not sure
can you help thank you
  • KTMCK Jan 03, 2008
    ok i uplugged the aerial with the amplifier so i had no signal the noise was still there, i took the dvd player out still made the noise and the free view box it still made the noise, But does not make the noise when watching a DVD, thanks
    Sergeant:
  • 271 Answers
Have you got your video connecting to your TV. or free view box if so disconnect it from the TV and free view box that should help if you have a video. If you don't then your (amplifier) is playing up let me know after you try this OK i will help you on your way
Posted on Jan 03, 2008
Connected a freeveiw box to my lg led hd tele but getting 2 halves of picture
could be bad conection or cables, sorry can't help more than that.
Jun 26, 2016 | LG 42SL9000 42 in. HD-Ready LED TV
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
I installed the zenith Digital converter box lastnight..used an digital amplified indoor antenna..only got 5 channels but today its not recieving signal at all and i bought another indoor antenna thinking...
I understand your issue as not getting the Digital reception from your converter box. The antenna plays an important role in what you can get. If you still have the Amplified antenna try to reduce the amplification and readjust the antenna positions. You might have to do this several times until you get it right. Also, if you live in a city and not a rural location do not use an amplified antenna and see if it is any better.
Good Luck.
Jul 12, 2009 | Zenith Analog to Digital Audio Converter
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
When tv is on it makes a loud buzzing noise
What is the make an and model of the set?
Is the buzzing from the speakers or from inside of the set?
Is it a high pitched frequency buzz or a low pitched frequency buzz?
There are many things that can cause a buzz in a TV set. In anycase, the set will require tech service.
Jerry G.
Jul 26, 2008 | Televison & Video
After attaching a freeview box to my Acoustic Solutions LCD32NK750HD 32" inch LCD HD TV the picture started to scramble and **** about the screen, this would stop when I turn the TV off and back on...
How have you got freeveiw connected to your set and what input are you using?
when connecting the freeveiw unit to the tv did you have the power connected and turned on to either tv or freeveiw?
how many sets are connected to the freeveiw unit,
All these things can affect this equation,
it sounds like the set had a power surge from the plugging in of the freeview,
the f connection output from the freeveiw set has a live voltage feed that powers either the mast head amp or the balun in the center of the dish,
for these to work correctly the cable between the freeveiw and the aerial/dish needs power,
this annoying little fault can only be remedied by taking it to the repair man,
Let us know the outcome thanks ,
hope this helps,
Jul 19, 2008 | Televison & Video
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
