Question about Mitsubishi WS-55513 55" Rear Projection HDTV
WS-55513....Just need confirmation of the problem
Woke up this morning to the led flashing problem. Seems like I have the same issue as a lot of others have posted here about the DM module, but the led on my set does not keep blinking constantly, it would go off for a while and then start blinking again. However the set is not turning on. So, I just need confirmation if this is the same problem or something else, and if there was a way to confirm it. I read in one of the solutions that pressing input and menu buttons together brings up the self diagnosis mode, can anyone please help with what buttons are these exactly. Appreciate any help.
  • 1 more comment
  • cipher64 Jan 03, 2008
    I don't think it is to do with a number, it is more to do with time. It flashes for about a minute then goes off and then starts flashing again for about a minute. That was a quick response, thanks. And hey it just came on, don't know if it will do this again. Is this an indicator of an imminent problem that might show itself later down the road? Thanks for yer help.
    I tried turning it off and on again and this time it came on without any problems.
  • cipher64 Jan 24, 2008
    I'm starting to have that problem again. I turn on the tv and the timer will blink for a certain amount of time and then it'll go off by itself. After that it's random, sometimes the tv will come on and sometimes it doesn't. But, if it does then it won't have any problems for the rest of the day. This is baffling, help please.
    President:
  • 4,402 Answers
First of all how many times does it blink on and off if it blinks a certain amount of times it's a service code
Posted on Jan 03, 2008
  • Cary Farah
    Cary Farah Jan 24, 2008
    http://www.chrisandnat.com/Projects/Blin...
    http://www.jeremyburns.com/Mitsubishi-Gr...
    http://www.fixya.com/howto/h159332-mitsu...
    http://hdtvoice.com/voice/showthread.php...
    replace DM
    Picture of bad caps
    http://www.auctioncreations.com/wd62525a...
    The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Dec 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS 55513...
sounds like the power supply board is unhappy
Mar 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Light flashing and tv won't turn on
you might want to have the power transformer checked to make sure its working correctly.sometimes when they go bad all you get is the flashing light
Oct 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I got a Mitsubishi WS-55513 55 in and the guy said i have to replace a fuse do you know anything about a fuse and the cost
What does the set do when you try to turn it on? What does the led light on the front of the set do?
let me know so i can help
Tim Nolan
Sep 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 screen keeps turning off
Yes, if you are handy, you can leave an e-mail address and I can send you a how to do repair guide with the factory service manual for your TV set and you will save at least 800 to 1000 bucks!
Jan 08, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Ws65813
Check threads for DM repair or ctechnicians.com
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws 55513 rear projection HDTV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Aug 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
