Question about SanDisk Sansa e250 MP3 Player
Sansa e250 wen i sync my sansa converter reads no device but its plugged in how do i solve this problem
  • tomtec Jan 26, 2008
    i got the songs on now it says it needs sync
  • 27 Answers
Put in MTP mode
Posted on Jan 25, 2008
SOURCE:
How come i cant sync my music onto my sansa e250 when i plug it into my new laptop but it does charge?
connect your sansa open mediA plAyer click on tools options devices double click on your sAnsA put A check next to start sync etc... click okAy i hope that works with windows media plAyer.....
May 31, 2009 | SanDisk Sansa e250 MP3 Player
Cannot delete the songs on mp3
I do mine through Windows Media Player
1)Plug in Sansa
2)Open up Windows Media Player and wait for the Sansa e250 icon to show up under the library. First time, might say 'What device is this' or 'Autoplay'-for autoplay,you click 'sync media files to Sansa e250 using WIndows Media Player'
3)When library shows, click 'Sync' if it is not already there.
4)Just simply click and drag the songs you want from the computer library to the list pane on the side.
5)Once your done, click 'Sart sync'
TO DELETE
1)Plug in
2)Wait for the icon under Library in WIndows Media Player
3)Go to Songs under Sansa e250
4)Right click desired songs and choose Delete. You only want to delete from Sansa e250-nothing else
~loli~
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
Answer this.
In your windows media you will see the device name listed..you have to make sure the device is under MTP mode..then click on the player and you will see all the songs...you can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Aug 17, 2008 | SanDisk Sansa e250 MP3 Player
Why won't my Sansa Media Converter recognize my Sansa e250 Mp3 player?
Mine won't read it in MTP mode. It works for me in MSC mode though.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
2GB Sansa e250 won't connect to my PC
After I download a song from the internet and try to sync it to my sansa mp3 player it gets on the mp3 player but won't play? It says continue your subscription to sync
Feb 09, 2008 | SanDisk Sansa e200 MP3 Player
Computer will not recognize Sansa e250 MP3 Player
You need to first update your firmware with a windows based computer (one update at a time in order). This will solve a ton of issues. Finally change the "USB Mode" to "MSC" with in the settings menu and you can enjoy your player
Jan 15, 2008 | SanDisk Sansa E280 MP3 Player
How do i get a video onto my sansa e250?
use the converter cd it came with, browse media, once the file is converted its add to the mp3 player i haven;t used it for video's yet only photo's but i'm sure it would work the same as long as its plugged in ofcourse
Jan 02, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 format??? HELP, PLEASE!
No You Don't Have To Converter The Tracks. It Depends On How You Put The Tracks On Your Sansa, Do You Drag And Drop Or Do You Sync With Copy To Device In Windows Media Player 9, Or Sync In Windows Media Player
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Media Converter will not locate the e250
Use volume + method listed below to get converter torecognize device
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 30, 2007 | SanDisk Sansa e250 MP3 Player
My mp3 wont let me convert songs, when i sync on wmp it says "error"
When i had this problem, i went to where it said Sansa e250 with the picture right clicked and it said fromat, this let me put my songs on the device but when it formats it everything on the device is deleted and you have to put it all back on, so if you're a patient person this the road to go on.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
