Question about Philips 42PF9946 42 in. EDTV-Ready Plasma Television
Philips 42PF9946 upgrade
Can i upgrade a plasma that is not hd ready to one that is? i bought this flat tv just before all the hd ready tvs came out.
    New Friend:
    Problem Solver:
  • 3 Answers
I am wondering the same thing. the tv is great but i dont want to change it but i want to get hd...
can anyone help
Posted on Nov 28, 2009
6ya staff
SOURCE:
Need 4 screws for phillips 42pf9946-12 plasma tv to fit wall bracket
Best way to be sure is call Philips customer service with the model number to get the thread type and length of these--no two sets are the same here---usually most will be available at local hardware stores if Phillips does not sell them(that would be a bit more pricey and take time).
Jun 15, 2012 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Hi, I've connected a Philips 42PF9946/79 Plasma TV to a Beyonwiz DP-Lite i Digital Set Top Box. The connection is through a HDMI Cable and TV is viewed on the 'HD' channel/mode. Previous to the Beyonwiz...
@leemcdowall...
your concern points to some adjustments of resolution from your set top box, as we all know all TV'S has fixed resolution doesnt matter what brand and the only way you can change that is through your source which in this set up is your Beyonwiz, please consult their manual and see if you can change the resolution in their video set up page.
Feb 20, 2011 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
I have a philips 43'' flat screen tv model number 42PF9945/12. When i switched it on the standby light came on and a clicking noise can be heard but the tv refuses to come off standby. how can i fix this?
Hello, I came across several times in this type of malfunction, stems from primary circuit of the power supply unit. I solved it by replacing the 5W ceramic resistor. In another case I came across electrolytic capacitors that i had to replace in the same circle. I hope it was helpful!
Nov 13, 2009 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV is a...
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Apr 16, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Can't get rid of HD-D in top corner of TV.
Solved it.
I called Philips and after some research (on their part) this was the solution.
  1. Make sure the PS3 is turned off
  2. Turn on the TV and put it onto the HD channel
  3. Hold the power button until you hear the second beep (roughly 5 secs)
  4. This brings up a screen saying 'a new HDMI device has been detected'
  5. Follow the prompts from here
Mar 19, 2009 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Philips 42PF9946 connect with laptop
Connect to the VGA port on the laptop, using a standard video cable.
Here is how VGA port looks like on your TV:
Note on some laptop you need to activate external video output by pressing a combination of keys, this will swap between laptop LCD video and external video.
Sep 13, 2008 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
No sound on philips 42pf9946/12
could it be that the sound is being directed through a optical output on the back of the telly?
Aug 02, 2008 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Philips 42pf9946/12
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Tv dead after storm
you could open it and look to see if the fuse is blown
Sep 22, 2007 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Philips 42PF9946 42 in. EDTV-Ready Plasma Television Logo
171 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
