Question about Motorola Mobility RAZR V3
Motorola Razr V3 wont delete
Hi, i have a Motorola Razr V3 but since 2 to 3 days ago i can't delete any ring tones that i have, and sometimes when i use the program of Motorola phone tools to put ring tones they wont pass to the phone can some one please help, at least i need to know how to delete my ring tones every time i try to delete them it just throw me out of the ring tone page please help.
Thanks
  • 54 Answers
Have you updated the firmware lately? Some of the newer versions wont let you delete your ringers once they are stored. Do you know how to use bitpim? If not shoot me an email and i can walk you through it. It is really easily to use. Good Luck!
Posted on Jan 05, 2008
SOURCE:
How can I unlock my Motorola Razr V3 subsidy code?
hi you can get the unlock codes from here
http://www.wickedunlock.com/motorola-razr-v3/rs11wp9/
they provide codes at reasonable cost.
May 19, 2011 | Motorola Mobility RAZR V3
Ring problem
I suggest that you download ringtones using a computer and using the mobile phones usb cable, transfer the downloaded ringtone to the mobile phone. It is much easier.
Jun 17, 2009 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
How to change the ring tone on my motorola V3 for
go into your ringtones and assign the msg alert to what you choose.
Jun 06, 2009 | Motorola Mobility RAZR V3
My razr v3 won't use dowloaded ringtones
you should have the phone debrand by flashing a new firmware on the phone and this would remove the block place in the phone.
Sep 30, 2008 | Motorola Mobility RAZR V3
Razr v3
Can you not go to sounds and set a ring tone from there?
I Used to have a Pebl U6,and thats how i set my ringtones.
Hope I Helped.
Sophie x
Feb 13, 2008 | Motorola Mobility RAZR V3
Ringing styles problem sir,,
try resetting your phone to its factory settings...
Oct 16, 2007 | Motorola Mobility RAZR V3
Cannot delete ringtones
HI Below is the step by step method of how to delete your ringtones in your Motorola V3: Here is an easier way to delete the ringtones without much hassle. 1) Upload 1 mp3 rintone to your phone via MPT 2) Set ALL ringtones msg, alert etc, absolutely everything for all styles (obviously excl. silent & vibe) to the uploaded MP3 3) switch your phone off, then on again. This will update the .db files. 4) Using P2K, delete all the rintones, except for the MP3 that you uploaded, do not delete the .db files. Also, do not delete the .bas files as these are the base files for Motomixer. Set all reminders to OFF. do not EVER delete a ringtone that is currently in use by the phone. If you delete it while it is active, You will NOT be able to get into that particular tone setting. 5) Switch your phone off, then on again.
May 01, 2007 | Motorola Mobility RAZR V3
Message alerts v3
I have this problem I can't access the loud setting but I can the soft I'm not yet sure why but you may need to update the software on your phone to fix this bug. Sometimes I take off the back and take out my battery and put it back in and then sometimes i can access also when you select your ring tone to change just push left or right instead of using the menu that drops down that also sometimes works for me hope one of the helps.
Feb 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
105 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
