Question about Shure E3C Consumer Headphones
Left ear does not work (very very weak sound)
Two sets of shure earphones
same problem - left side only 5% sound out
tried cleaning wax out - no wax
I forget the name of the sets - they are white - grey earphones - each cost around $299
  • tennisone Jan 03, 2008
    tried mulitple other audio devices, - same earphone problem
    ipod earhones work fine in all audio devices
    one set worked for a little over a year
    the newer set worked about 9 months
    I have two sets of cheaper earphones that work fine on all of the audio devices.
    There is not anything in between.
    Wait! I'm a moron - I confused my old broken set with my new set, and thought my new set was bad too.
    So now I'm down to this: my new set works fine with everything - my older set still has nothing coming out the left side. No wax in there that I can see or get out.
    If they are bad, your advice would be very helpful to figure out which company I can use to fix them and a rough estimate as to the cost.
    Sergeant:
    Champion:
  • 231 Answers
Try a regular cheap set of headphones on that device .If its the same ,then the audio device is the problem.Or try those sets of headphones on another audio device , computer,tv,cd or stereo receiver.If you are using any kind od adaptor inbetween those headphones and the audio device ,then check that..If they sound the same on any known good device..Then its possible they are bad ..let me know
Posted on Jan 03, 2008
  • crispin melchor Jan 03, 2008
    its also possible the the headphone cable is bad or the actual transducer on that side is bad ...
    if you know how to use a basic ohm meter .You can measure the resistance from both speakers.If you were to open the speaker enclosures from both ,you could measure the speaker directly.Use the good one as a reference .If the resistance or OHMS is the same for both diectly.Then the wire for bad side has risen in resistance thus bad.
6ya staff
SOURCE:
Right earphone seems somewhat quieter than the left earbud. At one point, it barely made any sound at all. Recently, it's decided to make itself louder. Still, I want to fix this. The sound quality in...
Did you tried interchanging them to the other side? If the problem changes side, try any other earphones to check that the problem is still there. If it goes, the the earphone could have a problem...try to look through the hole where the sound comes from and see if it is clogged by wax or any other thing.
Feb 02, 2018 | Monster Cable Products Turbine Headphones
Tip
SHURE E3g EARPHONE PROBLEM
IF YOU HAVE THE SAME PROBLEM WHAT I HAD WITH MY 3 YEAR OLD SURE E3g EARPHONE THAT ONE SIDE IS NOT LAUD ENOUGH......<br /> I DID TRY ALL THE CLEANING WITH THE PROVIDED TOOL BUT ALL DID NOT HELP.<br /> I DID USE A KNIFE AND DID SLOWELY FOLLOW THE GROVE ARROUND THE TIP OF MY BAD EARPHONE. AFTER A FEW MIN. WORKING WITH MY KNIFE IN THIS GROVE I DID FEEL THAT THE EARPHONE WILL COME APART. THE TIP HAS NO CONNECTIONS (ELECTRICAL SPEAKER WIRE CONNECTIONS) NOTHING IT IS JUST THE EARPHONE PLASTIC TIP. AFTER I HAD THE TIP IN MY HAND I USED A NEEDLE AND I GOT A LOT OLD EAR WAX OUT AND MY EARPHONE IS VERY LOAD AGAIN. NOW CLEAN BOTH SIDES AND PRESS THE TIP BACK ON. IF YOU FEEL BETTER USE A DROP SUPER GLUE TO BE SURE IT WILL NOT COME APART AGAIN AND STUCK IN YOUR EAR. I DID NOT USE ANY GLUE.<br /> I HOPE THIS DID HELP YOU TO CONTINUE TO LISTEN YOUR MUSIC WITH YOUR SURE E3g EARPHONE
on Mar 18, 2011 | Audio Players & Recorders
ONE side is muffled
This is caused by microscopic wax build up in one ear. You'll probably have to send the earphones to Shure for replacement.
Nov 05, 2010 | Shure E2C Consumer Headphones
Lh earphone of my Shure se210 volume is very low. Have cleaned the earpiece multiple time using the supplied tool. It sounds louder in the rear of the earpiece than inside of the ear. Any suggestions?
The dirt is clogged in the front end if the sound is clear at the rear. So it will be needed to clean the earpiece once again taking care to see that there is no dirt/ear wax clogging the sound vent.
If possible use fine bristles to brush out or clear the openings till the clarity improves since you mentioned the earpiece is working well when heard at the rear, if not the LH can be weak.
Sep 27, 2010 | Audio Players & Recorders
Shure earphone problem
There is no fix for that. They will need to be sent to Shure for repairs. Contact Shure Service.
May 01, 2010 | Shure E3C Consumer Headphones
One ear bud does not have full sound, i think it might be ear wax any way to safely clean with out damaging the speaker?
Sep 29, 2009 | Shure E4C Consumer Headphones
Only have sound on right side
I don't know if you used new earphones but if you did I would try to clean the inside of the mp3 player then reconnect youre earphone. If you still have the problem return to the store, then the hardware in the mp3 itself is wrong.
Dec 25, 2008 | SanDisk Sansa e260 MP3 Player
Shure E3C Consumer Headphones Logo
742 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Jerry Greenberg
Jerry Greenberg
Cameron Lewis
Cameron Lewis
Level 1 Expert
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
