hello sir, The clutch safety switch will kill the engine when the clutch/brake pedal is released. The deck switch will kill the engine when the blades are engaged. The seat switch will allow the engine to run when the rider isn't present. when the parking brake is set. instead of killing the engine when the rider isn't present. They don't usually give you any warning they just quit. You can check the safety switches if you make a jumper wire to use to complete the circuit. This will help determine which switches are bad.hope this helps, MrFixIt, oh could you please rate this solution,thank you~~~
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Craftsman 20 hp 42 in. Deck
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
YS 4500 20 hp 42 in. deck lawn tractor serial number. I will need the serial number in order to get...
(More)
YS 4500 20 hp 42 in. deck lawn tractor serial number. I will need the serial number in order to get the correct parts.
I have a 20hp 46" Craftsman Lawn Tractor and when I engage the PTO switch to activate the...
(More)
I have a 20hp 46" Craftsman Lawn Tractor and when I engage the PTO switch to activate the cutting blades they will run for about two minutes and then the switch will smoke and melt.......
I need to look at a wiring diagram for a 20 h.p. briggs and stratton engine,from the battery to the...
(More)
I need to look at a wiring diagram for a 20 h.p. briggs and stratton engine,from the battery to the selenoid to the ignition switch.
