Question about Frigidaire FDE336RE Dryer
Broken tumbler belt
How do I replace a broken tumbler drive belt on a Frigidaire Dryer?
The model is FDE336RES2.
Thank Eddee634270
  • Anonymous Feb 15, 2008
    gleq642as2 belt broken
  • Anonymous Mar 31, 2014
    Hi, is there a user guide to replace the dryer belting for frigidaire td950?
  • 283 Answers
Slide a putty knife or other thin object between the top and front panels a couple inches in from either side. Press in and release the two spring clips holding the top panel and at the same time lift it up and lean it back. Remove the screws inside the front corners holding the front panel on. Place the new belt around the drum in about the same position as the old one was. Remove the lower rear panel to access pulleys. place belt around the motor pulley. Stretch the idler arm over and place belt around pulley. Reassemble.
Posted on Jan 03, 2008
  • chris_mccrum Apr 23, 2011
    Ok i have all of it apart our belt broke. Now the spring on the pulley is free were does it hook and how will the belt go then
    On end goes on the idler pulley bracket. The other goes into a hole on the motor mount frame
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 03, 2011 | Frigidaire Dryers
Frigidaire dryer model FDE336RES2 won't run when you push the button. How to troubleshoot? I check power to unit and its OK. could it be the thermal limit part?
There can be many reasons why your dryer will not start orturn...
Sep 21, 2010 | Frigidaire FDE336RE Dryer
Frideraire dryer model fde336res2 won't eat. The
Take a look at #36 in the breakdown I have attached. This part is called a thermal limiter and blows if the heat is restricted in any way to cause the dryer to get too hot. You need to make sure that you don't have a lint buildup around the motor and in your vent hose. The part number for this part is 530320912. Hope this helps.250
Nov 19, 2009 | Frigidaire Dryers
My frigidaire heavy duty dryer model number FDE336RES2, starts to squeak once it turns on. It will continue to do this until it warms up then it stops. How do I fix this?
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does? SOME PICTURES
Sep 07, 2009 | Frigidaire FDE336RE Dryer
Does not spin. how to remove back.
you wont be able to remove back on most models you remove top cover to view drum, then if belt is broken remove the front to finish belt repl
Jul 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not heat up
check that you didnt disturb any wireing by mistake. then chec the contunity on your heating element. they are actually pretty fragile.
Apr 25, 2009 | Frigidaire FDE336RE Dryer
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Drum not spinning
Pretty easy fix. start by popping the top
Once you get that up then remove the front. The rear hatch gives access to the idler assembly, look in there to see the status of the belt before popping the top. The bumping could have been from a bad st of glides on front or a bad bearing on back. Impossible to tell till ya give it a look see.
Jan 06, 2009 | Frigidaire FDE336RE Dryer
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
259 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
