Question about Sony VAIO K15 Notebook
Overheating laptop The fan on my computer is constantly running.  The bottom of the laptop gets extremely warm.  Also, my CD burner has stopped working.  Any suggestions?
  • Kevin Croissant Jun 13, 2008
    I have this problem too. Except My cd drive still works. BUt, the
    overheating went too far and made the plastic melt to my desk. I got a
    new case, and a new battery since that was dieing. I can only use it
    for about 30 minutes before it will become so hot i have to get oven
    mits to pick it up. That bad!
  • 56 Answers
Well Try cleaning the air vents and use the system on a flat surface like a table as the air flow might not be flowing inside the system.And also there could be an issue with the heatsink on the system.As for the Cd Burner try using the system restore and see if that works
Posted on Jan 03, 2008
ACER ASPIRE 5738-6969 OVERHEATING DURING GAMING
Sounds like you have dust and dirt blocking your air flow. You probably need to take the laptop apart to get to the CPU fan and heat dissipation unit. You need to clean out all the dust in there to let the air flow freely. Get a service manual to help you take the laptop apart or find a local repair expert.
Nov 26, 2017 | Lifetime Computers & Internet
HP nc 6220 overheating? problem.
It sounds like you do have an overheating problem. When the laptop is running, peek inside the vent on the side or bottom of the laptop and determine if the fan is running. If it is running slow or completely stoped, that is your issue and it should be replaced by a local repair shop.
If the fan seems to be running fine, you may be able to deal with the problem and extend the life of the laptop a little by buying a laptop "cooling pad" which will have cooling fans of its own.
May 30, 2010 | HP Compaq nc6220 Notebook
My Sony Vaio laptop turns off constantly. It
When it is running I need to know if the air coming out of the vent slats is hot or just warm. It sounds like the laptop is overheating and shutting down so it doesn;t burn itself up. Get a can of compressed air they sell at office supplt companies and use short bursts of air in the vent slots and fan housing. If there is an access panel on the bottom that allows access to the processor and heatsink, blow that area out too. Then check the Sony support site and see if they have a BIOS update for that model computer. Some manufacturers are writing new BIOS instructions for their laptops for the fans to run longer and faster to take care of heat issues.
Sep 06, 2009 | Sony VAIO PCG-K35 Notebook
Hp 6720s lap top running - vista does not load
If the laptop runs extremely hot, then CPU will shut down (thermal overload) and will not boot up again until it has cooled down.
Overheating problems is caused by faulty fan (stop spinning) or the fan and heatsink assembly is clogged with dust. Check the fan, it should spin freely and remove and vacuum the dust from the fan and heatsink.
Replace the fan if it is faulty.
Aug 03, 2009 | HP Compaq 6720s PC Notebook
My computer is overheating and how do u clean the fan
need to blow all the dust out of the vents on the side and bottom of laptop and check out the fan while the laptop is running. If the fan seems to be running slow, the bearings may be damaged and you may need to get another fan.
Jun 01, 2009 | HP Compaq nx9010
Constant whirring- fan?
The whirring sound could mean the computer is running pretty warm and the fan is working hard to cool it. Or your fan is flat out going bad in which case replace it. One thing you might try is to get a can of compressed air (BlowOff) and see if you can get some dust out that may make you computer run cooler and your fan run smoother.
please leave rating, thank you kindly
Apr 29, 2009 | Computers & Internet
Think it is over heating
Ours kept stopping as it overheated - soluion was to get a chap platform to elevate the laptop which allowed it to 'breathe' a bit better and hasn't stopped since. We orginally had it directly on the desk so the air wasn't circulating
Oct 23, 2008 | HP Pavilion zd8000 Notebook
W34oua gateway system restore download
You need to solve the overheating problem first. Shut down the computer, unplug it and remove the bottom cover. Clean the dust and lint. Blow compressed air from a compressed air can. Re-install the cover and restart your computer. If you own a laptop, the fan should be running ALL THE TIME, sometimes slow, sometimes fast buta always running. Check the the fan is blowing air. If it is not, you'll need to replace it before doing anything else.
Aug 03, 2008 | Twinhead N14RATK Notebook
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Sony VAIO K15 Notebook Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
