I have an almost 12 year old mixer, and in the last year it seems the head (for lack of a more technical term), is a little lower so that the paddle attachment grinds on the bottom of the bowl. The coating of my paddle attachment has come off at the bottom from continued use. Is there some way to fix this?
Tegan, sorry to hear you tilt mixer head is drooping and causing rubbing problems with the mixing bowl. This should be pretty easy to fix, if you?ve got a small blade screw driver and a small hex driver (or jewelers screw driver). First, do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use KSM90P) and select one of the files that appear under Parts List. Turn to page 4 - Case, Gearing and Planetary unit, which shows the exploded view diagram and locate Illus. Nos. 29 & 30. Page 5 lists the parts as Adjusting Screw and Set Screw respectively. What?s probably happened is that over 12 years of operation, the vibrations from your mixer has caused the set screw to loosen and drop, hence the lower mixer head. Both screws will need to be ?adjusted? to move the head back to its original position. Now the problem is removing the head from its pedestal. Turn to page 8 and gently remove Illus. No. 7, Hinge Pin, with a hammer and pin driver. With the hinge pin removed the mixer head and pedestal can be separated and you should have access to adjusting and set screws. I would inspect them for wear and tear, and replace them, if you deem appropriate. It may take a few trial reassemblies to get the mixer head back to the original factory position, but once there, everything should be OK. I hope this helps! Howard, Burke, VA
the speed selector switch will not stay "off'. does not catch. any movement of the mixer...
(More)
the speed selector switch will not stay "off'. does not catch. any movement of the mixer causes spring to pull lever out of the off position. Turned on when I was changing mixer tool catching my hand.
when moving, the mixer was placed on its side for a period of time, causing oil to leak out into the...
(More)
WHEN MOVING, THE MIXER WAS PLACED ON ITS SIDE FOR A PERIOD OF TIME, CAUSING OIL TO LEAK OUT INTO THE PACKING BOX. NOW IT GETS HOT AND SHUTS DOWN. HELP
The kitchenaid ice cream maker drive assembly does not fit on to my mixer because of a metal disk...
(More)
The kitchenaid ice cream maker drive assembly does not fit on to my mixer because of a metal disk below the spring on the beater shaft. Is there a way of removing this disk and is it needed?
