Question about Sony Cyber-shot DSC-S600 Digital Camera
Power Button is stuck down
My camera first started to print No access, turn camera on again. Unable to take pictures, thought the batteries were dead, they were not. Now the power button is stuck in the down position and the camera will not turn on at all.
  • 1 more comment
  • garyolsson Jan 27, 2008
    my camera power button also seems to be stuck down and can't get it to turn on at all
  • dmhancock Jan 28, 2008
    Same problem.  I have tried several new batteries.  I hope someone can offer a solution.  Thanks.
  • Anonymous Mar 25, 2008
    I have the same problem with the power button stuck down. Unfortunately I have take some picture. When I tried to use a card reader to fetch picture from the memory card, there is an I/O error and I could not even retrieve any picture
  • 104 Answers
Sir,this is common for this model. internal micro switch conecting lever is broken u replace
Posted on Mar 24, 2008
It put access than after it starts beeping and appears turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Dec 12, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
Jun 21, 2008 | Fuji FinePix A345 Digital Camera
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
Jan 30, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Hi I am trying to Connect my new Pogo Printer to my Canon Powershot A40 and having trouble, can you help?
I have that camera and a new Pogo printer. To print, attach the camera to the printer with a USB cable. Make sure the camera's "take pictures/view pictures" slide switch is in the down view pictures position. Turn on the printer, turn on the camera. Select the picture to print. Press the camera's FUNC SET button. Accept the default settings and press the FUNC SET button again. In a few seconds, your picture should start to print.
Dec 25, 2008 | Polaroid PoGo Digital Photo Printer
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Unable to take Pictures
So, you're using Ni-MH batteries already, once you've turned it on and then you have to press on the PLAY button to view pictures, i need you to double check the battery type option of your camera by doing the steps below:
- Press MENU
- Scroll to the right until you are in SETUP 2
- Go down to Battery Type
- Switch it over to Ni-MH (for Rechargeable batteries)
- Select Alkaline (for Non-rechargeable batteries)
- Press MENU/OK for changes to be saved
Turn off camera for a few seconds so settings will be refreshed.
Turn on camera without pressing on the PLAY button to double check if it works.
If it does not work still, try to turn on again camera and immediately press on PLAY button to view pictures. Try to press again on PLAY button so you'll be on the mode to
take a picture.
If it still does not work, can you please try Non-rechargeable batteries (Alkaline) with your camera if it won't work with the Nickel-metal Hydride (Ni-MH) Rechargeable batteries.
Make sure you have set properly the battery type of the camera under SETUP 2 for Alkaline.
take a picture.
If it still won't work, then you have to send the camera for Repair.
Register camera online:
- Go to www.samsungcamerausa.com
- Click on Customer Service
- Register under Option 2 Box
- Fill out the required info
- Read instructions
- If website asked you to upload a receipt, just skip that
step and leave it blank
- Take note of the ASC address and online ticket number
that will be generated at the last step
- Turn-Around-Time will be 7-14 business days
Do the following:
- Include a copy of receipt in the box to avail of the warranty
- If you don't have any receipt, include a copy of credit/debit card statement/cancelled check that was used to purchase the camera
- Exclude all accessories when sending camera for repair
(No batteries, memory card, strap, cables, manual, CD)
- Write the online ticket number on top of the box
- Use another box and sealed it properly to avoid damages during shipment
- Check repair status using Online your zip code and phone number as you proceed on the Repair status of the website
Sep 14, 2007 | Samsung Digimax S630 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
148 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
