my dryer model kenmore 110.85862400 has power but does not turn on...is it possible that I locked it somehow? Do you know how I can unlock if thats the case. Someone told me to check fuses or breaker as well.. i don't know.. The light on the inside turns out so I know I have power but again does not turn on..Thanks for your help!
Faulty door button or faulty thermo cut out located on the heater housing Check for oms
Door switch when pushed in and thermal switch when power is applied
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 7.0 cu. ft. HE4
need to replace wires inside. Has error code of E2. Need a picture diagram of parts so I can order...
(More)
need to replace wires inside. Has error code of E2. Need a picture diagram of parts so I can order them. Dryer was filled with lint inside the machine. We took off the front panel and vacuumed it out. But most of the wires look bad slightly melted. I need a picture of the inside of the machine with the door off so I can order the wires. Do you have that available? Most of them just unplug and plug in, so it should be easy to replace. As long as I can order the right wires.
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power...
(More)
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power going to the washer but it is just dead. Is there a fuse in the washer that can be changed or something I can look at.
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what...
(More)
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what should i do?
