Question about Hitachi HDT725050VLAT80 500 GB EIDE Hard Drive
Problem not resolved new to the site
When i open hardware maagement the disc is show in proeties it says it is working properly but unable to reformat or add any dat my os is vista home premium ,it is only recognized when i us nternally but not externally via usb or firewire,a i need to use this as a media player external i need HELP to get it working ,quadcore chip 8gb ram asus extreme motherboard raptor 74 x2 in riad0 ] 4 50gb hitachi 500gb sata discs only one not working is the 500 ide via usb
  • 2 more comments
  • dayled Jan 03, 2008
    anyone know why my disc is not recognized os vista home premium i have tried using the disc internaly and is recognized but as i need the ide for my dvd`cd drives i am using it externaly to avail any answers out there
    the hard drive is a ide not a sata widows say my computer does not need the do download this file and will not run it.i can format the disc on my main computer but nothing from pc + lapotop as an external drive have swapped onto 3 other cases and nothing .
  • dayled Jan 04, 2008
    i can see the drive in disc managment and properties say it is working ok just cannot find it on desktop computer ordisc format and partition prog in vista only works internally on ide cables and is formattable and works fine but i need it for external use all other3 external drives are seen and work fine
  • dayled Jan 05, 2008
    tried all no luck when i plug in the comp says usb device not recognized and when i follow up i am told that no driver has been assigned to this device have tried reset drive master /slave . when i use another hd no problem when i use internelly no problem also cannot format to fat32 for some reason
    but that is a minor problem cannot figure out why internally works fine but via usb/firewire external media player/drive case nothing a brand new drive will try anything
  • 1,226 Answers
External drive is not recognize by windows vista, please updates the motherboard chips and you can download it here.
after downloading install it to your system.
You must install all necessary driver of your stuff. may be your external drive has a driver on its website for vista.
Posted on Jan 04, 2008
  • Emelio Navaja
    Emelio Navaja Jan 04, 2008
    If the drive still not recognize, go to computer management, then click disk management , you can see all the drive there.
  • 36 Answers
Vista has a big problem recognizing usb drives - and no one has one right way to fix this yet. The first thing you should try is installing this update from microsoft that combines all USB hotfixes into one download. (it's update 941600). Scroll down to "More Information" and download the version of the fix that applies to your vista installation.
If that still doesn't work, try following the instructions here, and deleting your .inf files.
Posted on Jan 03, 2008
  • Lucus Keppel
    Lucus Keppel Jan 06, 2008
    You may also try clicking "search for drivers myself" (when the Install Hardware) and browse to C:\Windows\System 32. Check the "include subfolders" box - sometimes Vista decides to "forget" where the .inf files are stored.
    I'm also trying to find a solution that worked on my system - one of the Windows Updates causes this problem with Vista not recognizing new USB devices.That update is KB936003 - "cumulative update for USB devices". To uninstall it (and see if it helps your system), go to the control panel, click on "Uninstall a program" and click on "Remove Windows Components" on the left-hand side of the window. Scroll down through the list until you see KB 936003, select it, and hit uninstall. Now unplug your usb-harddrive and plug it back in.
  • 317 Answers
The only way to use this externally would be to get an ide/sata to usb adapter, like this:
As for using it internally, you would connect it with the same ribbon cable that is connected to your current hard drive. Then the new drive you would have to set to slave, there will be a jumper on the end of the drive where you plug it in. It should tell you where to move the jumper to to set it as slave.
  • Peter Burns Jan 04, 2008
    If you get the adapter like I mentioned you will be able to use the drive externally, and that's the only way you'll be able to do it. And the kit works with and ide or sata drive. Since your drive is sata, then there's no problem.
Hardware wizard is unable to install drivers in any of my hardware
Remove the wizard and go to the manufacturer web site
Mar 14, 2014 | Computers & Internet
It doest work since it is newly formatted
If you're talking about the operating system not loading since you've newly reformatted, I'm guessing that you didn't actually reformat it correctly. I recommend running your recovery discs again in order to get it working properly.
If you're talking about some sort of hardware malfunction, but the computer is booting up correctly, then its probably a simple driver problem. Visit your manufacturer website and download/install the latest well as updating your OS.
May 03, 2011 | ASUS Computers & Internet
Need to format laptop computer as I am suspecting a virus attack. I am unable to open files, and does not show drives.
You can reformat your computer by using your recovery discs. Please keep in mind that if you reformat your computer you will be unable to recover any of your files that are currently on it. If you are able to, backup everything you can. You can use an external harddrive or a flash drive to get files off if you boot from a Linux LiveCD if you have access to a working computer with a CD burner and a CD. Post back if you need any help with that.
Mar 02, 2011 | Toshiba Satellite A135-S2276 Notebook
The CDRW/DVD doesn't work. Light comes on when inserting disc but the goes off. When I click open on the icon it says to "insert disc" This a Philips CDRW/DVD and when I go to the Hardware under...
When you are there in Device Manager use the option to update driver and see if that resolves the issue.
Are you burning a cd or dvd, or just reading disks; and what version windows are you using?
Mar 09, 2010 | Dell Dimension™ 4600C PC Desktop
WD My Book not showing up in ''My Computer'' I have read through the other threads here and tried most all suggestions outside of taking my hard drive apart. The drive has not been dropped and seems to be...
It sound like to me that you have an operating system on that
drive and it will not work on your system , the only way you
can have two OS on your computer is to have both of them
installed and on when installing the OS and they both have
to be formatted the same like NTFS or FAT32 even though
Windows says it will work fine with both its just not true XP
and Vista doesn't work well with both , try taking it out of
its closer and powering it up with your computer go into
Bios and set it up as a slave or as a master that should
allow you to open it to retrieve your data so it can be
reformatted wiped clean and ready to use as a static
HDD storage , external HDD are intended for storage
back ups and should never have an OS installed on them
doing so will only allow your data to become corrupt
and contract viruses and even lock up forever corrupting
the HDD image that is set on it by the RAM . once the
image is corrupt the HDD will never turn on again without
wiping it clean and reformatting .
Jan 19, 2010 | Computers & Internet
Board not detect the hard disc
Check on the jumper setting of the ide and power cable
check if the ide cable is connected properly on ur mother board/try reverse if u are not sure it doesnt ur hardware.
Start on power button the then click on on delete continuesly until the cmos setup will appear then check ur hardisk and ur boot secquence.
sometime not delete are using using in opening cmos sometime f2 or whatever assign.
Use fdisk/to check ur partition/after that reformat in these case u can easily conclude if ur hardisk is bad or not
Jun 10, 2009 | ASUS M2N-MX Motherboard
Sound card not detected
Go to the following link and download the audio drivers to install for your notebook:
There is a link for Windows Vista or XP drivers. Let me know if this helps resolve your issue.
Mar 23, 2009 | Lenovo 3000 Y410 Notebook
I have a built in dvd/cd rw drive in my laptop and it will not play CDs or DVDs anymore. It opens and whirls briefly when I put a CD in, but then nothing opens up. In explorer D drive doesn't show. ...
You have not mentioned that which operating system you areusing. I am providing you with a link of Microsoft. Just follow thelink and i am sure that the issue you are facing will be resolved.
Click Here
The article may have a different heading however this will resolve the issue you are facing. Follow the steps and delete the upper and lower filters.
All the Best
Sep 03, 2008 | Computers & Internet
"LOAD" Showing on the display
Exactly the same problem myself. Try pressing open and then holding tight to a cotton bud, sweep inside the machine. The problem seems to be dust collecting. If it works then get a proper cleaning disc. My problem got so bad that the machine would spit out most discs as unable to read.
May 16, 2008 | Samsung DVDR120 DVD Recorder
Hard drive not rcognized
Hi i think you need to change the jumper settings on the back of the hd to tell your comp that this isnt the main hd if you have allready done this then the only sollution is to trace down the software that came with that hd.
You might be able to get it off the net i will also look for you and check to see if the jumper setting are causing you problems i will post back as soon as i find anything out ok let me know how you get pn
Jan 03, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
Hitachi HDT725050VLAT80 500 GB EIDE Hard Drive Logo
132 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
