if its a handchiffted gearbox put in highest gear. puch the car to the front and back till you hear a click. if he starts .check the ignition.if this is not correct the car have a death spot.
There's 2 fuses. Fuse 5 is the right side Fuse 7 is the left side Both are 30 amp and are located in the fuse block inside the car. (drivers side kick panel)
The fuse must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search the windows fuse, it should be around 30 amps.
According with the Owners Manual, this fuse is located in Passenger compartment fuse panel. The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover.
Check the position 43, 20 AMP CB for Power Windows
Hope this helps; keep inn touch and remember to rate this answer.
Have you checked the fuses yet? The low beams use 2 different fuse for the left and right lamps. The fuse for the left lamp is #10 in the central junction box located behind the dash to the left of the steering column.
