Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Had a power outage, acer monitor will not power up
Is there a fuse i can change inside the monitor?
  • Fredonia Jan 06, 2008
    Same problem with a Samsung 730B after power outage. Power cord connected to same surge protected power strip as the computer -- computer is fine, monitor has no image.
  • 146 Answers
Normally there is a fuse that can be replaced inside on the power supply board. The are usually "slow blow" fuses and need to be replaced by an equivalent fuse. Many monitors have a soft switch which is controlled by the main board that tells the relays to supply power from the power supply. The CMOS devices on these boards are very suceptible to static so ground your hand to the chassis before touching any boards. If the backlight is out but there is a faint image on the screen when you look at it closely then the inverter board or CFT tubes are suspect. BTW: watch the Power supply and inverter boards as the caps stay charged and could result in electrical shock. Good luck. Hope this helps.
Posted on Jan 03, 2008
6ya staff
SOURCE:
Monitor not powering up
Hi
Try the power cable.Could've been blown.
Switch it with the CPU'S and see what happens.
Mar 02, 2012 | Compaq FP 7020 17" Flat Panel LCD Monitor
.won't turn on. all plugs are in properly. has
When you turn on the main power socket to the monitor, does the front LED turn come on (Green/Orange)? If not, try changing the power cord or the fuse inside the power cord.
Feb 19, 2011 | Acer X183H 18" Monitor
Acer monitor suffers power outage; screen shows very dark colors
There is no key to use for opening the case. Please see the service manuals here:
http://elektrotanya.com/?q=showresult&megnev=ACER megnev2% 20 & = & Category = & AL1916 kat2 = all
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 07, 2010 | Acer AL1916W 19" LCD Monitor
Monitor blinking after power outage
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 26, 2010 | Acer AL1914 19" LCD Monitor
What can i do if my acer lcd monitor haven't power
May 19, 2010 | Acer AL1917W LCD Monitor
The power went out twice in a one hour period a couple of days ago. After the second outage, my monitor would not come back on. Unfortunately, I had removed it from the surge protector to plug something...
1) Have you checked the fuse in the mains plug ?
2) There may also be a secondary fuse, inside the monitor (don't as me how to dismantle it, all I know is carefully) on the main cct board near to the power in socket.
Mar 14, 2010 | Acer AL1916W 19" LCD Monitor
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
327 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
