My pioneer sd-533hd5 is 8-9 years old. It works great, I just want to clean the lenses. What is the best way to access them? If I should remove the front , how do i do it? I can't see any way to remove it. thanks
You should be able to access it from the back panel. After you remove the panel, the lenses should be mounted on a platform. If you are careful, you can manuever yourself in far enough to clean the inside of the display screen. Good luck!
Was this helpful?
Yes
No
Popular Solutions for Pioneer SD-533HD5 53 in. Rear
picture disappears while TV is on. When TV is turned off for a while, it turns back on, but only...
(More)
picture disappears while TV is on. When TV is turned off for a while, it turns back on, but only runs for about 5 minutes and then turns off again.
my protective screen is cracked on my pioneer sd533hd how can i remove it I need to know how to...
(More)
my protective screen is cracked on my pioneer sd533hd how can i remove it I need to know how to remove it and were i can by a replacement
