Question about Braun Cafe Select Coffee/Espresso Mill Grinder
Braun KMM30 Coffee & Mill Grinder
Does not grind at all. Timer works but nothing happens.
  • Anonymous Mar 16, 2008
    Braun coffee/Expresso Mill 3045 looks like model KMM30 . Does not work at all. Was fine and then just stopped...
Same problem here
Posted on Jul 17, 2010
How can we fix a nutri-mill wheat grinder?
can you see the grinding wheel /blades . if so try to rotate it /them slightly by hand
Dec 17, 2015 | Nutrimill Grain Mill Grinder
Can I grind coffee in an electric grain mill?
Electric grain mills were not designed to grind up oily grains like coffee, you would be better off getting either a hand grinder or a coffee grinder.
Jan 23, 2014 | Kitchen Appliances - Others
Fill beans
the coffee beans are not entering in the grinder disks and since they rotate without coffee the machine understands that their is no beans. You need to clean the grinder disk and grinding coffee funel to bee sure their nothing blocking the coffee movements. Use a vaccum cleaner and try to clean everything in grinder and grinder exits. Try also the machine by regulating thegriding to more gross coffee and when it will start grinding normal then you can udjust step by step back to grinding position you have at the begeining.
Feb 27, 2012 | DeLonghi ESAM 5500M
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
I have a Braun coffee grinder made in Mexico.Since the last week or so,the grinder has stopped working.When the black switch(pushdown button on the top) is pressed,nothing happens. Please...
May have a short in the wires. Test with a multimeter for continuity. If wires are not shorted out, motor may have a wire that has broken or come loose.
Feb 06, 2011 | Braun Coffee Makers & Espresso Machines
Grinder stalls constantly (motor whirring, but no grinding happening) so I shake it to get it grinding again, but the whirring/no grinding happens over and over. I have to shake the think 5 or 6 times to...
As I can see, what happens is that some coffee grains stucks in the way from the upper pot to the grinding wheel. This is not something usual, but possible if coffee grains are too big and are placed across the entry of the mill. Try cleaning more deep with some old toothbrush. Look for a clean and even surface of the duct.
Other cause might be a loosen mill hub/grinding wheel off the motor shaft, which would require dissassemble of the appliance to be repaired.
Dec 10, 2010 | Krups Burr Coffee Grinder
How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Jul 13, 2009 | Braun KSM 2 Electric Blades Grinder
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
Coffee Makers & Espresso Machines Logo
294 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
