When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat -- defective selector switch -- defective gas safety valve -- defective gas valve coils...
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
This helps me get started. Much apprecialted!
" - john_davidso
Popular Solutions for Magic Chef 31000 Gas Kitchen
oven does not turn on! I can smell the gas, I think the pilot flame went off, and I don't know how...
(More)
oven does not turn on! I can smell the gas, I think the pilot flame went off, and I don't know how to turn it on!
The pilot lite is lit, and when you turn the oven on, the flame drops but never lites the burner,...
(More)
The pilot lite is lit, and when you turn the oven on, the flame drops but never lites the burner, smell of gas is present
the timer keeps going of,if was reset to zero on the timer and stopped,but went off on its own 5...
(More)
the timer keeps going of,if was reset to zero on the timer and stopped,but went off on its own 5 hours later
