Keyboard fault HP
My hp keyboard is not set up correctly and keeps repeating when you press shift and the " and @ are the wrong way round do i need a new driver and where do i get one from p/n:5187-4431 s/n:by50303970
  • 23 Answers
Hello Barralee
You should modify your "international settings" in the section "details" at control panel to correct that "keyboard distribution"
Posted on Jan 06, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Barralee
You also can change your keyboard, and install a new Hp Usb new one, with drivers.
www.Hp.com
or in comp-usa
Posted on Jan 05, 2008
    Genius:
  • 1,226 Answers
Instead finding printer driver, you should install first all the drivers of PC/Laptop. By entering some data about your PC/Laptop you can find your driver here: http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Please install the correct driver of your PC/Laptop to optimize its performance.
Posted on Jan 04, 2008
My HP laptop working on Windows 10 is not properly entering@ symbol when I press shift 2
I would check for firmware updates. Basically make sure you have all your updates. I would see if the Key is working at all. the 2 or the SHIFT key. It may be a hardware issue if its just that key. Which would result in needing a replacement keyboard.
Apr 26, 2017 | HP Computers & Internet
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    When i type shift + 3 i get " instead of @ what could be the problem
    Depends on you keyboard layout, check the settings in start -> settings -> control panel -> regional an language options, go to the 'Languages' tab and click 'Details' and select the correct keyboard layout.
    Jan 28, 2011 | HP Compaq 2510p Notebook
    @ button not producing symbol types as ' ' & "" with shift key
    The first thing you should do is just check and make sure your keyboard location settings are correct.The UK keyboard layout is different to the US keyboardfor example.
    It could be that your settings have be changed and if that is the case you will find your @ and " are the wrong way round.
    I posted a walkthrough with a video here on the site that may help you eliminate this as the cause of your problem. http://www.fixya.com/support/r7863937-change_default_keyboard_layout_in
    Hope this help you with your problem.
    Jan 18, 2011 | Computers & Internet
    Shift+2 gives "; shift +3 gives pound symbol;
    It sounds like your keymap is off.
    Try this:
    http://www.conversationexchange.com/resources/keyboard-language.php
    Nov 28, 2010 | HP Computers & Internet
    I have HP Compaq nc6220, but Every time I want to insert the @ symbol I have to press "Shift & the 2 button". The symbol above the 2 key shows is " But if I press the key that has the...
    You will need to goto the control panel goto reginal setting and set to your country, then goto the language tab at the top goto details, adjust this at the top using the small arrow to bring down the other choices set this to england united kingdom click apply then ok and exit out of all open windows now check your keyboard, if still the same reboot the computer then try hopfully your keyboard will be as you want it. hope this helps and post back if you have dificulties.
    Oct 27, 2010 | HP Compaq nc6220 Notebook
    Hi my @ key wont work on my hp laptop it's a compaq nx6110 can you help plz?
    Try holding down the ALT GR button on the right side of the long space bar, then while holding it down press on 2 to obtain @
    But I suppose in US keyboards you get @ by pressing SHIFT and 2. if that does not work check control panel, regional and language settings, make sure the keyboard language and layout are correct.
    Oct 03, 2010 | HP Laptop Keyboard for HP Compaq Presario...
    I have an HP Pavillion ze5300 laptop, and most of the time (15 out of every 20 minutes about) the "]" key keeps repeating. Sometime I can type if I am pressing the backspace key the entire time, but that...
    It sounds like you need to replace the keyboard. Replacing the keyboard is not difficult or you can take it to a repair center. Parts can be ordered online from HP or aftermarket vendors.
    Dec 09, 2009 | Saitek Executive PZ18AU Keyboard
    When I press Shift 2, I do not get @, but I get " instead. how do I solve this?
    Your system is has the wrong language settings.
    Go to the control palel/ regional and language settings/
    Set the correct country from the drop down box then click the languages tab/details and do the same. Apply and exit all should be OK now
    Sep 14, 2009 | HP DC170B Keyboard
    Computers & Internet Logo
    114 people viewed this question
    David Payne
    David Payne
