Question about Samsung SGH-E900 Cellular Phone
Turn off write protection on a sd micro card
How do you turn off the write protection on a sd micro card. when I formated it with my phone it write protected it and there is nothing on the card. I cant download anything to the card or reformat it. Please help!!!!
  • 4 more comments
  • joyankees May 23, 2008
    i cant put songs on my sd
  • Anonymous Jul 02, 2008
    same problem why isn't it working?!
  • Anonymous Oct 29, 2008
    how do you get the protection off of an sd card
  • yush010228 Jan 06, 2009
    My mobile Samsung E 250, is not switching on.
  • Anonymous Mar 17, 2014
    my micro sd card not support. please help me.
  • Anonymous Mar 18, 2014
    the phone switches on and off on its own. sometimes I can hear people who call me or if I call them, sometimes I cant. this started after last software upgrade
    President:
  • 1,017 Answers
In the menu, tools, memory card, options you should find the setting for memory card password on/off
Posted on Jan 04, 2008
6ya staff
SOURCE:
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
Using a SanDisk Micro in a SanDisk adapter in a USB Card Reader. My system keeps reporting the card is write protected, no matter the position of the lock switch. I formatted the SD in my phone, no...
Most SD memory cards have a tiny slide switch on the edge of the card. Move this slide switch from Read to Write to turn off the write protection.
Nov 12, 2010 | SanDisk 2GB microSD Memory Card
Micro sd memory card for 3110c password protected was forgotten
connect ur memory card, to the comp. through card reader,, then format it,,, lock will be opend
Jan 09, 2010 | Nokia 3110 Cellular Phone
Can't format my kingston micro sd memory card
you may do not have administrative rights to format [or it may be password protected]
Sep 11, 2009 | Nokia 6233 Cellular Phone
There's a little slide thing, on the side of the big chip that the little micro sd slides into. Just slide it and bam.
Jan 11, 2009 | LG Shine CU720 Cellular Phone
If you are using it with the SD adaptor, the swith at the side marked lock is not to secure the micro sd card within the adaptor. This is the write protection. If you set this to the 'unlocked' position (up) then you should be able to write files onto it!
Apr 04, 2008 | Nokia 6288 Cellular Phone
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Mar 08, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Micro sd card says write protect when inserted what does that mean
Hi , means you connot delete the picture , the only remedy to erase the write protect to format the micro sd , for the next time dont click to write protect .
Mar 03, 2008 | GE E1040 Digital Camera
Micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me [email protected] or [email protected]
Jan 07, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
389 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
