Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
High Spin problems -Whirlpool top load - LSB6300LWO
When my washer engages in high spin at the end of the cycle it gets violently off-balance. It is not the agitator and I've replaced the balancing spring and the two springs below the tub. It doesn't matter the load - it always does this. I can't figure out what the problem is. The balance ring has fluid in it and everything looks in good shape. any ideas??? I've been working on this for 3 months and nothing I've done has solved this issue.
  • 1 more comment
  • GSmith113 Jan 04, 2008
    I've also checked balancing legs and floor level.
  • GSmith113 Jan 05, 2008
    the washer is level and it is not a load-balance issue. it will make this violent rotation with a full load or with nothing but water in it. Also, the washer and floor are level.
    the above solution does not apply because the washer continues the cycle (high spin) although it must be manually stopped to prevent damage to it and surrounding objects. The washer does not suddenly stop without manual interupption. It only does this in the spin cycle, not agitation.
    posted by GSmith113 on Jan 04, 2008Report abuse
    Comment by GSmith113, posted on Jan 04, 2008
    Comment by GSmith113, posted on Jan 05, 2008
    Sergeant:
  • 264 Answers
Make sure the drum is empty put it on a program any one when the water is full and the drum starts to go round tune off the machine then put the program on the spin program to see if it is your pump some times or a lot of the time pumps on the machines time out or run relay slow that will make the machine run violently you probably need a 35w or a 42w pump so that way the water will pump out quicker and will stop the machine from running away. this should stop the problem.
Posted on Jan 05, 2008
    Problem Solver:
  • 72 Answers
The most common cause is an unbalanced wash load. Open the lid and when it comes to a stop, redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit.
A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See our article on how to level your washing machine.
The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
Another common cause for excessive movement is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.
There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
Posted on Jan 04, 2008
    Guru:
  • 1,894 Answers
I think washer's basket is stopping too suddenly at the end of spin.
  • dewan nafees ahmed Jan 04, 2008
    this solution was taken from this link.
    see if you understand anything from it
    If your washer stops spinning violently like I'm describing,
    within a second or two, you can cure it yourself (if it's not
    repaired, it can also cause serious damage to suspension
    components).
    Pickup a small tube of high temperature silicone-based
    grease from your local auto parts store. 'Sil-Glyde' is one
    common brand that I've used for many purposes over the
    years. A very handy grease to use around rubber components
    that petroleum lubes would attack. This is sold as automotive
    brake caliper lube, and if you ask for a small amount of
    that, they'll know what you mean. Buy the smallest amount
    available - you only need a tiny 'dab' on the end of a small
    screwdriver.
    Pull the washer's cabinet off (see note at the end of this
    article) and you'll see the chrome clutch drum, right above
    the transmission. Just above that is another, larger drum,
    and this one's the brake drum. On most, you'll see a foam
    'rubber band' noise dampener around it.
    Put a 1/4 inch 'dab' of silicone grease on the end of a small
    screwdriver (I use the pen-sized one carried in my shirt
    pocket), and look up into this brake drum.
    You'll want to insert the screwdriver between the brake coil
    spring and the inside of the drum. Apply the grease to the
    inside of the brake drum (the drum can be rotated by hand
    to bring this spring around).
    Be sure you're putting this into the UPPER drum (brake),
    and NOT the clutch drum, which is below it, and chrome in
    color. I've included a picture of the two drums in the online
    version of this article. You'll find that here:
    http://www.DavesRepair.com/DIYhelp/DIYdd...
    It would be very hard to put grease on the clutch linings
    inside the lower clutch drum, but I mention the possibility
    just in case there's a 'Tim Allen' type (like my big brother)
    out there who might take the 'more is better' approach .
    That's it! Solves the brake lockup problem, and it doesn't
    come back! No pulling the motor, gearcase, pump - or any
    of that fun stuff like I used to! As my 15 year old daughter
    would say, 'sweet!'.
    Note: In the interest of keeping this issue as short as
    possible, I didn't include directions for removing the washer
    cabinet. You'll find those in the instructions for replacing
    the drive coupler in these washers, at:
    http://www.DavesRepair.com/DIYhelp/DIY28... ;
Hi Have a WEC7500VW whirlpool front load washer shows a F25 code . Looked at the tech sheet in washer does not show that code what is it? Also washer will not spin out on high at end of cycle. Did the...
Not sure what you mean but if the washer doesn't spin then it's probably the switch that controls the spin action.
On most washers, when you open the lid or door the spin cycle stops for safety's sake. In many cases, there is a small extension on the door or lid that engages the switch when you close it. Look where the extension is supposed to engage and that's the switch. I was able to fix my broken switch on my GE washer by cutting the edge of the plastic on a pen and gluing it to the extension so it pushed the switch mechanism down further to start the spin cycle.
Hopes this helps.
Paul
Sep 29, 2014 | Washing Machines
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Why won't my washer go to a high speed spin when in the spin cycle? it drains the water out of the drum, but it doesn't go into the high speed spin.
well there is two possibilities and one is a safety precaution to keep from ruining the washer .
if the washer cannont distribute the load evenly it will only go into a slow spin try adding more clothes.... to evenly coat the drum >>. the other is if it is out of balance or the wsher isnt't level it will shake violently and spin in slow cause it detects an imbalance problem if this machine has operated a long time overladed , or unlevel it can wear out the tub schocks which takes all vibrations of the tub to give more of a gently ride the a are like schock absorbers....
Jan 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Off balance
make sure you have all the shipping material out of unit..4 bolts in back and styrofoam under tub if so ,then get a adjustable wrench ,,,put unit in drain spin cycle or spin cycle only..when unit gets to fastest spin ,,thats will come when its about 8 minutes left..tighten each leg lock nut on unit until unit stops vibrating..only turn the lock nut not the leg..only adjust lock nut on legs in high speed spin
Dec 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
239 people viewed this question
Dan Webster
Dan Webster
Sal De
