Question about Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau VG-352-812 Cook top
I need to replace the burner heads. do you know where i can order them?
Here are the diagrams, parts list, and sales of the parts. Specific to Gaggenau VG353. Additional site to order parts: Essentials For Your Home website, just put in the part number from the diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232110&diagram_id=193996#d193996
Posted on Sep 19, 2012
    Novelist:
  • 130 Answers
You should be able to go online to Gaggenau and in the service area there is a link for order parts
Posted on Jan 06, 2008
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
Gaggenau 200 Series?
If it is similar to the VE260 model, this induction type of cook top is very old. 22 - 23 years if it came with the home when it was built.
I can only offer basic suggestions of which you already probably know.
These induction type cook tops rely on the pan or skillet to be magnetic like stainless steel. If the bottom of the pan has any buildup of residue, this will dramatically reduce the efficiency of the unit.
If the pans are immaculate, then the electronic elements that produce the magnetic induction to heat the coils must be weak. As old as the unit is, it is probably not feasible to have 3 of the elements repaired....
A new top can be purchased much cheaper. Consult Consumers Reports for unbiased product reviews for your best reviews. As a final suggestion, find someone who is qualified to use an electrical multimeter to read the current on both sides of the power receptacle to ensure that your voltage is 230V. A loose connection on the receptacle can cause the elements to have the same result.
Although I can imagine you have already done everything above, I just wanted to send you what I can offer.
Jan 02, 2014 | Gaggenau Cooktops
I need the two front knobs that come out from the front lower inside unit that are the igniter controls for tge gaggenau vg 353 112 cd. Please lead me to the part numbers and a parts supplier. Thanks brian
Jan 16, 2011 | Gaggenau 15 in. VG 353 Gas Cooktop
Cook top burner knobs all 4 not able to turn
Just to be clear, non of the 4 burner controls/knobs will turn ? You are familiar with this unit are you ?
Typically you must push down and turn to activate them.
Let me know if that is not the solution.
Good Luck :)
Oct 29, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
Dec 11, 2008 | Dacor Preference SGM466 Gas Cooktop
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
Burner head covers
POWDER-COATING IS THE BEST BUT PRICEY AS-WELL. GO TO THE AUTO STORE AND TRY USING HI-GLOSS HEAT RESISTANT ENGINE PAINT. THEY HAVE BLACK AND SEVERAL OTHER COLORS. MAKE SURE TO READ AND FOLLOW THE INSTUCTIONS ON THE SPRAY-CAN CAREFULLY.
Apr 30, 2007 | Gaggenau 23 in. KG 260 Gas Cooktop
Flame too low
Most probably dirty jets. If water was spuilled, there is a possibility of rust forming on some parts. Low flames are usually due to inadequate gas supply, due to dirty jets and burners. Often rust forms on the top burners in the little holes, causing slight blockage - clean the holes with a needle properly and check. Oshie
Jul 30, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau 23 in. KG 260 Gas Cooktop Logo
699 people viewed this question
Top Gaggenau Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
