ViewSonic VX2433WM 23.6" Monitor Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen cuts off image
How do you adjust the monitor to show the whole screen? it seems to cut the left hand side of the image off.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 14, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1819
Points
5
To see the button on the right hand side of this monitor you will need to shine a really bright light on it, but the buttons from top to bottom are: 1, up-arrrow, down-arrow, and 2.
  1. On the side of the monitor press the 1 button to activate the menu.
  2. A configuration menu for the monitor will appear; from that menu highlight the "Input Select" menu item using the up and down buttons on the monitor; when you have the item high-lighted, press the 2 key.
  3. A new menu will appear, and then you can select the menu item called HDMI on the left and PC waaay over on the right. Select this menu item with the up and down arrows and when it is selected,
  4. And press 2 like you did in the previous step.
Apparently there's some sort of a strange difference between using this monitor as a "video monitor" and using it with a computer.
  • PreachArch Mar 12, 2012
    Solution worked for me!!! Thank you Jesus! --Architect
shaun
Level 2:
Sergeant:
  • Expert 233 Answers
  • Posted on Nov 02, 2009
shaun
Expert
Level 2:
Sergeant:
Answers
233
Questions
0
Helped
58579
Points
580
Ther should be a group of small buttons on your monitor one will let u select the menu then use the button to select what u want to do move screen up or down or right or left.check u have driver for monitor.
1helpful
My Viewsonic 2235 monitor only shows the desktop top on 70% of the upper screen. It was fine and I ran Paretologic. When I rebooted, the screen images are egg shaped or stretched out side to side. ...
If you have an Auto Adjust option on your monitor, press that and it should adjust the screen to the correct size.
The button should be on the panel or it might be a setting in the monitor settings itself.
Hope that helps
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Uncentered image using projector
reset the settings to factory default. is it cut off evenly, or is it uneven and shadowed? if it is the latter and you have a dlp projector, you have a collapsed light tunnel. if it is cut off evenly, go into the settings and make sure the resolution and screen size matches.
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Items in picture are not all there
Hi...there,
Well, right click on your mouse and select properties. Next click on settings and on your left hands side you will see a screen resolution. Move the bar to your right to your desired settings. Caution: To see the whole pages your types will be much smaller than your previous...settings. Have fun!
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Problem with truncated image from data projector
You will need to setup the displays from the computer running the projector.
Setup the projector as being a second monitor pretty much and make the adjustments from that in display properties on your computer, or your video card may have it's own control panel for this as well.
Hope it helps =)
4helpful
2answers
Xbox 360 screen cut off on left side
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Off center screen
on the computer there is a button called menu press it. use the position tool and put both of them equal eg 50-50
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
