Question about Motorola Mobility RAZR V3x Cellular Phone
Mororola phone tools
Cant get my disk to run even going to the run setup. I accidental put the cord on the phone and computer before installing the disk now the disk wont run.
  • 3 Answers
Is ur disk lready crrupted?
Posted on Jan 05, 2008
I cannot start my computer after replacing motherboard and CPU. How do i install Windows onto the motherboard and how do I install eJiffy?
You forgot to sysprep the OS before removing the old board.
Put the drive back on the old board and CPU and let it boot up.
now sysprep the drive THEN re-install the new board and CPU
To sysprep the drive, do the following:
>There is a SYSPREP tool on the XP CD.
>You may need to extract files from the Windows XP CD, files are located at CD:\SUPPORT\TOOLS\ in a cab file called DEPLOY.CAB. The files are Sysprep.exe and Setupcl.exe.
>With the old motherboard still intact:
>You run sysprep and "RESEAL" Windows XP.
>Then you put the new board in, and it re-activates Windows XP and populates the device manager list.
>You do need to re-activate with the same key-code, and if you exhaust that number of activations, it will prompt you to call Microsoft and you get a new release key at no cost from them over the phone.
The basic problem here is that when windows goes to initialize the old hard disk controller, it loses the hard disk because the controller isn't the same.
It may also be crashing as it tries to initialize other hardware, but it needs that IDE or SATA (or SCSI) controller online even to get into safe mode!!
Good luck - sysprep works about 90% of the time, but if you run into problems, it can be a real bugger to untangle!
Feb 27, 2011 | Computers & Internet
I forgot my desktop password cant get into my computer what do i do?
DO NOT panic! You definitely have 100% chances to enter the locked computer withn several minutes.
Windows Password Recovery is right the tool that you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system including Windows 7, Vista, XP etc. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy, I am sure you can handle it!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive. Note: start computer and press F2 or Delete to enter BISO setup
Step 4: Boot your locked computer from the created disk and remove your forgotten password. GOOD LUCK! :)
Feb 18, 2011 | Compaq Presario 5000 PC Desktop
Help!!!! i cant put music into my huawei m750
your m750 should of came with a usb cord. the is site i use is www.zedge.com and what i do is download my ringtones to a specific folder so that i can find it. first plug your usb into your phone and then into the computer..exit all that pops up and even if you get a message to the right that will say driver could not install, still close it out then download what ringtone you may have and then go to computer removable disk k or what ever removable disk that is not normally there and double click on it and it will put up what is on the phone and then go to the folder in which you save the ringtone and right click the ringtone and then send it to the removable disk k and then it should show how it's being transferred to what is on you phone move the ringtone to your music folder and then close out the pages go to your phone and click files and go to music and it should be there
Jan 30, 2010 | Cell Phones
Transferring photos from LG Vu to my computer
Though usual manage assistants can help you back the android phone, sometimes you may feel that is troublesome and not easy. Looking for android phone manager? It can backup Android Photos and transfer to PC. Easy way to Backup Photos on Android
Usually, you can back the android phone with USB, but sometimes you may feel that is troublesome and not easy. Looking for android phone manager?
Manage Your Android Device Efficiently It can transfer SMS from android to PC easily
Jun 15, 2009 | LG Vu CU920 Cellular Phone
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Im having problemx installibg sims deluxe edition
Dear mz_bridg_ett,First of all you need to check that your computer hardware/ the entire computer meets the specifications of the game. you will be looking at things like
CPU speed -- the higher the number in MHz you have the better
RAM speed -- this is your computers' memory, the bigger the number in MB/ GB and MHz the better
HDD size -- this is your hard disk drive, bigger the number in GB the better. . . . typical size is 120-500Gb and will be enough for the game . . . . . . more than enough even with Windows (EWWW YUCK!! ) installed on it.
GPU speed-- this is your graphics disply, and like the rest, the bigger the number the better, best to check out your specifications before you attempt to play the game.... ideally you want a direct x 9.0c card or better still direct x 10 when in windows (YUCK) go to start>run>command>dxdiag ... this will check that for you
Right with that lot done, open your CD drive, and put the install disc into the drive, and it should start to run automatically. . . . if not go to my computer and find the CD drive letter and double click it. . . . . if you are a smarty pants like me, then you can go to start>run>command>X:\autorun.exe...........substitute value "X" for your drive letter, you can also type....start>run>command>X:\setup.exe..... for Vista (awwww ewww awful) then you need to go start>all programs>accessories>command prompt> command.com...... then follow the above for other version of windows.
game should start to load, ask you where you want to install it, and then for the password/ product key of the game, which you can find on the back of the manual or on the reverse inside of the CD case.
enter the code then hit ok
When this is done, itll ask you to enter the game disk/ play disk if you dont have to reboot your computer, but i always reboot first anyway.
enter the play disk and run it like you did before with the install disk, unless you are one of the many masses that add shortcuts on your menu and systems to start up your programs/ warez.
if this doesnt work, try cleaning the disk, try installing it to different locations, even get diagnostic tools to check your computer. . . .
definitely try all above before feeding the game disks to the dog.
I hope this is the fixya for you
yours sincerely
Oz
Mar 13, 2009 | EA - Electronic Arts The Sims Deluxe...
I have a siemens modem from telus and i cant get it to be wirless even though it is i have to program it and i cant figure it out
Install the drivers. Did it come with a disk? Put the disk in and follow the prompts. If no disk, go to the site and get the drivers. It will explain what to do.
May 29, 2008 | Siemens Computers & Internet
Reconnecting up Brother mfc215c all in one
This machine MIGHT NOT support vista!
If you run XP you should download the aggressive remover tool and delete all drivers. After restart of pc install mfl-pro suite and wait until software demands the connection to mfc.
Never connect machine to a hub!
It must be connected to pc usb!
Feb 20, 2008 | Brother MFC 210C All-In-One InkJet Printer
About creating setup disk
no you cannot create an instillation from an installed copy of vista, altough the necessary files are there the is a lot more to the instilliation process than what is on your harddrive.. what you ned to do is uinstall fresh of the windows vista instilliation disc. if you dont have the disc i hope you got your srial... or you can download one using a torrent client such as utorrent and from this web site as the torrent
www.torrentspy.com.
Jan 06, 2008 | Microsoft Windows Vista Ultimate Edition
Cannot access memory card on Motorazr V9 phone
i face d same problem....solution for this is u hve to buy s software & tool cd of d phone....n thn just insert d disk install d software..now u can access d memory card...n that cd contain so many other tools n software..try this out..i m sure this ll work
Nov 10, 2007 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola Mobility RAZR V3x Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
