The point gap should be 0.013 inches. You should also check the end play and run out on the shaft before point installation (vertical & horizontal movement)- should be minimal or the engine will run erratic or not at all if too loose.
Remove valve cover,bring #1 cylinder top dead center,make sure both push rods are loose,put you dist in and were ever your rotor is pointed that will be your number one wire.then you will have to adjust you timing when started by ear,I hope this helps you
