Computer shutting off after a few seconds to a few minutes
This sounds like an auto shut-off signal given by the processor because of a possible over-heating issue. This usually happens when the laptop has been run for an extended time without having the dust, dirt and debris cleaned from its cooling vents and grills. After time, the thermal paste on the processor bakes under the extreme heat and starts to flake off and lose its efficiency at cooling the processor.
Get a few cans of compressed air that you would buy at an office supply store and using short bursts, blow out the dust and dirt from all the ventilation grills and vents first, make sure the laptop is powered down and battery removed. Then, open all the compartments and clean them out as well including the cd/dvd tray. There is a small black hole on the dvd bezel, just stick an open paperclip in it and it will pop the tray open. Blow a good blast in there to clean the dvd player.
There is the possibility that the thermal paste will have to be replaced, that means you need to gain access to the heatsink and remove from the processor, clean all the old thermal paste from it and apply a small thin layer of new paste to the top of the processor and replace the heatsink, securing it evenly with the attached screws.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 3000 PC Notebook
I require the SNID for an acer aspire 4730Z, and the back sticky is faded to where it is...
(More)
I require the SNID for an acer aspire 4730Z, and the back sticky is faded to where it is unreadable....Can I get help please?
My acer 3000 wont come on, but when i plug it in, and press the power button, the battery light...
(More)
My acer 3000 wont come on, but when i plug it in, and press the power button, the battery light blinks 8 X's then it just does nothing
at start up message appears re consistency disc and fat32 file. appears to boot normally except that...
(More)
AT START UP MESSAGE APPEARS RE CONSISTENCY DISC AND FAT32 FILE. APPEARS TO BOOT NORMALLY EXCEPT THAT THE DESK TOP IS DIFFERENT 'ACER BACKGROUND' AND THE CURSOR IS FROZEN. CANNOT SWITCH OFF AT THE POWER BUTTON. HAVE TO DISCONNECT POWER AND BATTERY.
When I open Internet - it will show modem operating, then it will say not operating and it...
(More)
When I open Internet - it will show modem operating, then it will say not operating and it continually goes up and down and internet is running slow when up. I called our Inet service company and went through all the checks and they said it's probably a program issue with the Acer E management program ???
