FixYa.com
Tags:
GE Spacemaker  Microwave Oven
Trips the circuit
posted by missmo2 on Jan 03, 2008
Runs for 3 or 4 seconds then the power goes off and I smell something burnt. Do I just buy another?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 06, 2008
Not Rated (0)
vettesrbadas
Rank:Master Master
Rating: 79%, 14 votes
magnatron seals? never heard of one of those before. i am 99.999% sure it is the magnatron itself. removing the upper grill and the control panel will not change anything. the magnatron is located back behind the control panel and is held in by 4 nuts.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I called GE about a unit running for 2 seconds and stopping, then stating the date and time needed to be entered. They agreed to pay for parts if I pay for labor. One repairman said it may be the manatron seal leaking and allowing microwaves to hit the control panel. He suggested removing the screws in the upper grill and then losoign one or two screws that hold the control panel in place. Tip it forward and try running the machine. If it runs okay, then the seals are the problem. I plan to try this tomrrow (it's in a rental unti) and take it in Monday to a shop.
Jim Alex
Can you Help with these Microwave Ovens problems?
GE Spacemaker (JVM1640SJ) Microwave Oven
GE Spacemaker Problem
Model JVM1851 - Doesn't heat,... Answer This...
GE Profile Spacemaker XL1800...
When you grasp the door handle,... Answer This...
GE JVM231WV001 Stopped Working
Everything was fine with this... Answer This...
Problem Fixed?
I have the same problem as you.... Answer This...
GE Spacemaker XL1800 Buzzes
Got up one morning and... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
