Question about Hitachi HDT725050VLAT80 500 GB EIDE Hard Drive
Hard drive not rcognized
When i open hardware maagement the disc is show in proeties it says it is working properly but unable to reformat or add any dat my os is vista home premium ,it is only recognized when i us nternally but not externally via usb or firewire,a i need to use this as a media player external i need HELP to get it working ,quadcore chip 8gb ram asus extreme motherboard raptor 74 x2 in riad0 ] 4 50gb hitachi 500gb sata discs only one not working is the 500 ide via usb
  • robbyw57 May 18, 2009
    I have just tryed to use my hard drive internaly as a slave and externaly on a USB connection. I get the same results with the 'jumpers' set to master or slave device manager says it's working OK but I don't get a new drive letter (eg DRIVE F). Can not be seen.
  • 4,102 Answers
Hi i think you need to change the jumper settings on the back of the hd to tell your comp that this isnt the main hd if you have allready done this then the only sollution is to trace down the software that came with that hd.
You might be able to get it off the net i will also look for you and check to see if the jumper setting are causing you problems i will post back as soon as i find anything out ok let me know how you get pn
Posted on Jan 03, 2008
2 Suggested Answers
Raveler
  • 36 Answers
SOURCE: problem not resolved new to the site
Vista has a big problem recognizing usb drives - and no one has one right way to fix this yet. The first thing you should try is installing this update from microsoft that combines all USB hotfixes into one download. (it's update 941600). Scroll down to "More Information" and download the version of the fix that applies to your vista installation.
If that still doesn't work, try following the instructions here, and deleting your .inf files.
Windows is unable to read the usb
When you formatted the drive for the Mac, you probably used the HFS format. Windows can only read NTFS or FAT formatted drives. You will need to reformat your external drive again. If you use a FAT32 format, all computers will be able to read the drive (Windows, UNIX and Mac - anyway). Note: the FAT32 option does limit the number of files in each directory and the maximum file size.
First back up any files that you have put on the external drive to another disc (your computer's hard disc, for example).
If you are using the M2 external disc for Time Machine backups, you should partition the drive into two sections. Format one to the FAT32 and the other to HFS.
The Disc Utility in OSX can repartition the drive and reformat it. However, sometimes it doesn't correctly format the new partitions. You may need to do some extra step, see http://www.cs.ubc.ca/~pcarbo/macnexstar.html for one set of reformatting steps. In Windows, there is a similar utitily in the Disk Management Control Panel. (Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions (Windows 7)) You can only format the disc to FAT or NTFS with the Windows utility.
Some third-party software is available for changing the partitions on a hard drive formatted for Windows use without losing the data on the disc. I do not know if similar programs exist for OSX.
Some versions of Unix have gparted which will also repartion and reformat a hard disc but can't keep the original data on the drive. (I've used the Windows and Unix partition managers, including Paragon Partition Manager which let me keep my original Windows data on the drive.)
I hope this helps.
Apr 12, 2012 | Samsung M2 PORTABLE 320GB USB20 HARD DRIVE...
Problem not resolved new to the site
The only way to use this externally would be to get an ide/sata to usb adapter, like this:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=470
As for using it internally, you would connect it with the same ribbon cable that is connected to your current hard drive. Then the new drive you would have to set to slave, there will be a jumper on the end of the drive where you plug it in. It should tell you where to move the jumper to to set it as slave.
Jan 03, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
My Western Digital 520 MB portable hard drive is not showing up on my mac. I see its white light blipping constantly but it is not appearing on my computer. It worked a few times the past few days but it...
Try reformatting the drive. In Mac OSX go to the utilities Folder open up Disk Utility. In left hand window of the page you will see your drive. Highlight it. At top of page click on Erase. In Format drop down window select Mac OS Extended (Journaled). In window below format give your disk a name. At bottom of page click Erase.
After you have erased and reformatted click on First Aid at top of page. In First Aid highlight your disc and click on Repair Disc at bottom right hand of page. after Disc Repair try using it again and see if that works.
If it doesn't work repeat the above steps And if the doesn't work try another disc or go for a long walk and breath deeply.
Aug 30, 2010 | Western Digital My Book Home Edition 500...
WD My Book not showing up in ''My Computer'' I have read through the other threads here and tried most all suggestions outside of taking my hard drive apart. The drive has not been dropped and seems to be...
It sound like to me that you have an operating system on that
drive and it will not work on your system , the only way you
can have two OS on your computer is to have both of them
installed and on when installing the OS and they both have
to be formatted the same like NTFS or FAT32 even though
Windows says it will work fine with both its just not true XP
and Vista doesn't work well with both , try taking it out of
its closer and powering it up with your computer go into
Bios and set it up as a slave or as a master that should
allow you to open it to retrieve your data so it can be
reformatted wiped clean and ready to use as a static
HDD storage , external HDD are intended for storage
back ups and should never have an OS installed on them
doing so will only allow your data to become corrupt
and contract viruses and even lock up forever corrupting
the HDD image that is set on it by the RAM . once the
image is corrupt the HDD will never turn on again without
wiping it clean and reformatting .
Jan 19, 2010 | Computers & Internet
I don,t know how to copy files on a scan disc
Open Windows Explorer, assuming you're running Windows, and the flash drive should show up with a drive letter, e.g. as E:\ (Doesn't matter what letter.) Copy or drag the files or folders you want to move from this drive to your hard drive, assuming that's where you want them.
It's a good idea not to use Cut and Paste when doing this so the original still exists on the flash drive in case of problems.
Once you've copied what you want from your flash drive, you can reformat it if you wish. Click on Safely Remove Hardware before removing your flash drive from the USB port.
Nov 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 250 GB My Book external hard drive it shows it is working okay, but when I try to open it, it says to insert a disc. When I check to reformat, it shows no media and will not open. What's my...
Dear, It looks like issue with the the hardisk module (mostly the interface board inside the box). You can still try by connecting to different pc or by changing the USB cable
Oct 15, 2009 | Western Digital My Book Essential Edition...
My labtop will not get passed a black screen
This is generally caused by a hard drive failure, and 8 out of 10 times the hard drive needs replaced. However, it could be an operating system glitch. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, the reformat the hard drive, and install a new operating system. If the hard drive will not format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Aug 23, 2008 | Dell Inspiron E1505 Notebook
Installation not happening
if you put it show Or auto run it ?
if test Any pendriver put ..what can show ..if it show &run it you try any other pc..other way you try add new hardware install...hope it ok.......
Jun 14, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Unable to reformat tablet pc with targus external drive
Can you get into the bios, and change the boot order, make the CD Drive the first boot device. Make sure your CD is a bootable CD.
Mar 19, 2008 | Computers & Internet
Hitachi HDT725050VLAT80 500 GB EIDE Hard Drive Logo
309 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
