Question about HP Compaq nx6110 PC Laptop
USB CONNECTOR BROKE!
My brother trip on my charger and bump my laptop to the ground while having my mouse in the usb port and my usb port and now my usb is not usuable and sometime it shorts when you try to plug something into the usb port. Do you know where I can find a replacement usb connector? I open up the laptop already and all I have to do is desolder the bad one out and resolder a new one in. What is the part number? Any help will be great!
Thanks!
    President:
  • 4,402 Answers
Get a broken motherboard on ebay and desolder the usb port thats one and put it on this one.
or you can look for one at digikey.com
Posted on Jan 03, 2008
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
The mouse cursor on my laptop wandering without control?
This is what they call device interference, You might have to many wireless devices connected to a single USB port on your PC. Sometimes its a struggle between keyboard and mouse both wireless. Solution would be to limit the wireless devices to certain USB ports. For ex: plug the wireless keyboard to opposite USB port from the wireless mouse, vise versa. If you are using a multi-port USB connector, unplug the mouse from the multi-port and plug it to a single USB port on the PC.
Oct 20, 2014 | Sony VAIO Computers & Internet
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
Charger port not straight and is tricky to connect charger to. Used usb to charge on laptop and the plug smoked
If this is a desktop then the USB connector is wrongly connected from inside plz check the connection from inside
Oct 22, 2013 | ASUS Eee Computers & Internet
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
ALL USB PORT IS NOT WORKING.MY KEYBOARD AND MOUSE AS WELL.
If you are running Windows, Do the following:
  • Control Panel
  • Hardware
  • Device Manager
  • Check USB settings / properties
Drivers could be corrupted / uninstall and let system find and re-install
Feb 09, 2011 | ASUS P5B Deluxe Motherboard
I broke my USB port on my Acer Aspire 4730Z. How
open the laptop, desktop pc, and remove carefully the internal usb connector, that goes to the motherboard, BEFORE ANYTHING DISCONNECT THE POWER CABLE, AND EVERY SINGLE CABLE ITS CONNECTED TO, MOUSE, KEYBOARD...ETC. then see which kind it is, and go to your local hardware store, Best Buy, Fry's, or order it online.
Reply: team.akwrite@gmail.com Irving
Mar 16, 2010 | Computers & Internet
I was sold a mouse...with a round end....where is the portal on the computer?
That end is a PS/2 connector most modern day laptops do NOT have this connector, you need a USB Mouse, I suggest you take it back and try and swap it, for one compatible with your PC.
Feb 22, 2010 | HP Presario C555nr Notebook
The part that goes into the USB port broke off in the port. How do I procure a replacement? This happened as I accidently bumped it while moving my laptop.
Searching the web for that P/N shows the model is the V200 mouse. You mean you want a replacement USB receiver (not antenna, since that's just a small part inside the receiver). Logitech sells some replacement receivers (usually $10 + S/H). Contact Logitech Sales at 800-231-7717 (US and Canada only), see the Contact page, or check the Support->Downloads + Parts section as some models now list receivers there for sale.
You can also E-mail Support.
If it is covered by the warranty: Less than 30 days since purchase, you need to exchange it where you got it.
After 30 days, you would be covered under the 3 or 5 year warranty from Logitech.
See here for RMA info.
Mar 20, 2009 | Logitech Cordless Mouse
HP Compaq nx6110 PC Laptop Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
