HP Pavilion a1220n  PC Desktop
Installing Windows XP on new drive in HP a220n
posted by Scary Larry on Jan 03, 2008
HD went bad on this HP Pavilion a220n. I have a copy of Windows XP Pro that I want to install on it. The Bios sees the drive but I couldn't get XP to load due to the application saying the partition is incorrect. I partitioned the drive in a Dell Dimension with the XP disk. I then tried to load XP onto the new drive in the HP and it still says the partition is wrong and won't install. I partititioned it as NTFS.
Got any ideas?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 04, 2008
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 89%, 1445 votes
Your new hard drive has a name, like Seagate, Western Digtail, bla, bla... Go to the Mfg's web site for your drive. Download the bootable floppy disk manager setup utilities. If you have a floppy disk drive. If you don't have a floppy drive most Mfg's allow you to make a bootable CD. Lastly or maybe I should have mentioned this first. Make sure your drive is pinned out correctly. I'm only guessing you bought an IDE drive which has a jumper for setting the drive as a master or a slave or a master with a slave.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Installing Windows XP on new drive in HP a220n:
I don't want to Accept this solution
Can you Help with these PC Desktops problems?
PC Desktops
I have no luck getting help from this co.I have rang to...
PC Desktops
the computer im checking on is not this one. the model no....
HP Pavilion a1220n (A1220NED904AA) PC...
actually my boyfriend did it. he's not here because he...
The drive on this PC got corrupted. I formatted it and...
The original drive got corrupted. I put in a fresh drive...
Loading problems.
Repair Service
Find PC Desktop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
