Question about Canon i860 InkJet Photo Printer
CANON i860 PRINTER - ERROR SIGNALS
Whe power is applied, the printer sounds like it is trying to initialize, but there is no print head movement. Then I get what I assume is a "service call" error with the power LED blinking one green then four orange flashes. This continues to repeat and pressing the "resume" button has no effect. I have tried to enter the "Service Mode" by following the OEM manual instructions, but the printer does not respond. Can't find a good parts source for either the logic board assembly, or the purge unit which the manual indicates is probably causing the malfunction if this is in fact a "service call" error. Would appreciate your thoughts and recommendations on further troubleshooting, disassembly, and procurement of parts.
Thanks,
E-Mail [email protected] Wally Hart
  • 1 more comment
  • mainsailor Jan 04, 2008
    Mainsailor - Thanks for your input. I am just recovering from some surgery, so it is going to be a few days before I can open up the printer and work on it, but I really appreciate your help. Will let you know what success I have when I do get so I can work on the unit.
    Wally Hart
  • Anonymous Jun 14, 2008
    Hi, I am having the same problem with my I860. I've gotten the cover off but exactly what idoes the purge unit look like and where is the white release. Is this under the print head and cartridges. Thanks for any help you can give
    Hi, I am having the same problem with my I860. I had printed a 20 page document and then I got the green and orange lights. I've gotten the cover off but what does the purge unit look like and where is the white release button? Is this under the ink cartridges and print head?
    Thanks for any help that anyone can give
  • 52 Answers
Hi i am a certified Canon tech for a repair shop on the east coast of the united states. by what u are describing the problem seem to be with the purge unit that it is not spining to release the carridge unit. this could be due to something stuck in the purge unit or in its gears. if you take the top cover off the machine on the right side is the purge unit towards the back of the unit is a white release that has to be pushed down inorder to move the carridge unit. once that is released you can look into the purge and check for things jammed in the gears or obstructing the up and down operation of the purge pad and the back and forth operation of the wiper assy. if everything looks normal the purge unit most likely is still at fault and can be purched for 30-40 dollars plus shipping.
Posted on Jan 04, 2008
6ya staff
SOURCE:
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
3e black cartridge not printing. Canon i860
Did you try another cartridge?
What can happen sometimes is that the print head can get blocked.
You can clean that by removing the print head from the printer. Do not touch the foil on the head or the print nozzles.
Boil some water, pour 1/4 of an inch (6mm) of water into a saucer, place the print nozzles in the water for a minute or so.
Take the print head out of the water and touch it on a paper towel to get the water off.
Reassemble the printer and see what happens...
Feb 20, 2010 | Canon Office Equipment & Supplies
My Canon i860 just can't print out black words, it's frustrating
pull the ink cartage back out to see if a clear film is not on the cartage??? Check the area by cleaning the ink cartage with rubbing alchole, and also the area that the ink cartage goes into. Use a cotton ball the clean these area with.
Jan 31, 2009 | Canon i860 InkJet Photo Printer
After deep cleaning the print heads, it will only print one page
This sounds like the print head alignment is not stabilized and may indicate you need a new print head ($$$). Try looking in the Service Manual.
A copy of the Canon i860 Service Manual is downloadable at:
http://rapidshare.com/files/179582794/Canon_i860__i865_SM_-_printer1.blogspot.com.rar
The password to open the compressed PDF file is: printer1.blogspot.com
Jan 24, 2009 | Canon i860 InkJet Photo Printer
Canon i860 error codes
Try this: With your i860 printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Sep 15, 2008 | Canon i860 InkJet Photo Printer
Canon i860
Print head temperature rise [5200]
I would assume that the cleaning efforts resulted in oveheating the print heads.
Please ensure that you have sufficient ink, as ink acts as a lubricant for the heads.If you try to use them while empty it is equivalent to driving a car without oil.
Take your time..
Verify ink is in all cartridges.
Remove paper jam
let the printer cool off (heads)
Chances are the head alignment is not necessary and you are low on one of the inks...
Try this test program (Page) to isolate low colors...
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Feb 10, 2008 | Canon i860 InkJet Photo Printer
I860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Dec 29, 2007 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
352 people viewed this question
Clive
Clive
old marine
old marine
Ekse
