Coleman Propane Forced Air Heater w/Electronic Ignition
Problem for Coleman Propane Forced Air Heater w/Electronic Ignition...
PROBLEM WITH COLEMAN DGAA070BDTB FURNACE KICKS ON
By ermartinez31 on Nov 02, 2009
PROBLEM WITH COLEMAN DGAA070BDTB FURNACE KICKS ON BUT THE AIR IS COLD THROUGH THE REGISTERS. SEEMS THAT THE FAN SWITCH IS TURNING THE FAN ON TO EARLY
Solution #1
posted on Nov 02, 2009
Not Rated)
rmk800
Rank: Master
Rating: 80%, 7 votes
you have a bad ignitor or gas valve call your local heating repair company
Was this helpful?
Yes
No
Popular Solutions for Coleman Propane Forced Air
Questions and Unsolved Problems for Coleman Propane Forced Air
Do you recommend Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)?
Answer
Answer
My Coleman furnaces with electronic ignition just stopped working I think its the ignition. how do I... (More)
Answer
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution... (More)
Answer
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble... (More)
Answer
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then... (More)
Answer
i have a pro comp pc9001 distributor multi-spark box with a pc91 coil..my problem is where does the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Propane Forced Air...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
