Why does my washer leaks
My washer leaks every now and then. it is PAVT910AWW maytag performa
  • 6277 Answers
SOURCE: Maytag Performa PAVT910AWW Top Loan
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 01, 2011
0 characters
1 Points
How old is Model #PAVT910AWW
If you go to the following website and fill in the information it will give you an approximate age of your machine. You will also need your serial number as well as the model.
Jul 30, 2014 | Maytag Performa PAV2200
What year is Performa washer model PAVT910AWW
Please check this with the dealer or from the website.
Magtag performa
Jan 21, 2013 | Maytag Washing Machines
Washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
Sep 14, 2009 | Maytag Performa PAV2200
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Washer wont agitate or spin
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Apr 21, 2009 | Maytag Performa PAV3200
My pavt910aww is full of water and has no power it seems???
You most likely have a bad lid switch.
Check the switch with a volt/ohm meter set for continuity.
No reading on the meter is a bad switch.
Feb 25, 2009 | Maytag Performa PAV3200
Wash mach. will not agetate only hums
Oct 11, 2008 | Maytag Performa PAV3200
Maytag Performa washer
Hi jamac74
The leak could be comming from one of 2 places, either the pump or the main seal. the best way to find wherer the leak is comming from is to take the front panel off. you can do this by poping the top up there is 2 clips that hold the top down. use a putty knife to pop the top up then there is 2 screws holding the front on.
Sep 16, 2008 | Maytag Performa PAV2200
Performa PAVT910Aww
Apr 01, 2008 | Maytag Performa PAV3200
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
