Sony VAIO VGN-FJ270/B PC Notebook
Problem for Sony VAIO VGN-FJ270/B PC Notebook
Cannot restart after
By sbabolcsay on Nov 02, 2009
Cannot restart after "blue screen of death". Managed to get to a reboot screen but stuck in a loop. "windows xp cannot restart in safemode." but not the safemode I usally see.
Solution #1
posted on Nov 02, 2009
Not Rated)
parrotheadpc
Rank: Guru  Sony Computer Hardware  Expert
Rating: 89%, 545 votes
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Was this helpful?
Yes
No
Popular Solutions for Sony VAIO VGN-FJ270/B PC
Questions and Unsolved Problems for Sony VAIO VGN-FJ270/B PC
Do you recommend Sony VAIO VGN-FJ270/B PC Notebook?
Answer
Answer
i have a sony vaio laptop and i dont know how to set up the security motion eye and im not sure if... (More)
Answer
my pendrive will not load onto my 2003 powerpoint
Answer
i have changed computers and am unable to access jigsaw puzzles purchased in the name of... (More)
Answer
tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony VAIO VGN-FJ270/B PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
