Question about Refrigerators
Refrigerator My refrigerator isnt cooling anymore. It is a chefmate model bc-50a. I removed the back cover all fans are running but the condensor isnt getting cold. What should I look for or replace. Thanks Nate
  • Anonymous Apr 01, 2008
    Same problem. Only had this fridge for a few months and it isn't cooling at all. I don't see any kind of reset switch or anything like that either. If this is the case, it's a piece of junk purchase!
  • keekomalou Jul 30, 2008
    I have a chefmate BC-50A. It only worked for about a year. It's not cooling anymore, but there's power going to the unit. I can't hear the motor running.
    Please give suggestions.
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Posted on Jun 02, 2008
  • Ismael velasquez Feb 10, 2014
    hw to install eat and cold fans
Maytag refrigerator model msd2651heb not cooling. Hear fan running but not condensor
if you mean the compressor isn't running most likely you have a bad start device part 67005560,pull out machine unplug it and remove the bottom back panel,look at compressor,pop off metal clip and remove cover on the side of compressor,slide off the device and shake it,if the device is cooked you'll hear pieces rattling around inside it,install new part,if it still doesn't start could have a bad compressor.
Jul 14, 2012 | Refrigerators
Will not cool light does not come on when door is open Chefmate Model: BC-50A
unplug, take the back cover off.
Look at the circuit board.
at the top right of the board there is a fuse.
if it is blown, the frige is dead.
you will probily find that there is a brown burn mark
on the upper left side of the circuit board under an aluminum
heat sink. that electronic part probily overheated and blew up.
unless your electronics skils are up to it throw the frige away.
but if you are up to it unsolder it, bring it to frys electronics, and
get a new one. Good luck.
Aug 25, 2010 | Refrigerators
Condensor fan running all day
when you say you removed the cardboard, did you remove the back panel that covers the compressor, fan, and coils from the back? If so that is what is causing it to run too much, this will also effect the cooling.
May 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
remove motor and use the numbers on motor for replacement most appliance, hvac,and electrical supply stores even online carry replacement
May 06, 2010 | U-Line 15R Compact Refrigerator
The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Mar 25, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a Chefmate Mini Fridge - BC-50A that does not work. It appears the heat sink fan and the cold sink fan do not have power to the motor. What do I do?
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Nov 19, 2009 | LG GC-051SS Compact Refrigerator
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Refrigerator cools, but no freezer fan & no condensor fan running
Check the back of you fridge and make sure the coils are clean. If you have access to a small air compressor, blow everything out and make sure the motor are is clean. The build up of dirt on the coils will not let the heat escape during the cooling process.
Mar 04, 2008 | Jenn-Air JCD2389G Side by Side...
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
1,519 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
