Rudd Furnce not working properly
The board has 3 lights 2 green and 1 yellow When the second green light starts to flash it will not do anything What could the problem be?
    Problem Solver:
  • 12 Answers
On the door there should be a explanation on what the flash pattern means
let me know what it is
Posted on Jan 05, 2008
Need help to get my playstation working. tryed to
The Yellow Light of Death (YLoD) is a fatal error that occurs when your Playstation 3 (PS3) overheats.
The welds that connect vital components to the system board soften and break.
It's manifestation - a blinking yellow light on a PS3 that refuses to do anything else.
You have 2 options at this point:
  1. Return the unit to Sony.
    if your PS3 is still under warranty, the fix will be free; otherwise, Sony will charge a flat fee of $150.
  2. Fix it yourself for less than $80.
    This list contains the necessary tools and components to effect your PS3's meteoric rise from it's YLoDic grave as set forth in this free YLoD Repair Guide.
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
Canon I850 won't print , it has a green light for about 2 seconds then flashes a yellow light for about 6 seconds
Hi there
This is only a try it may do it but I not know,
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i850)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 19, 2010 | Canon i850 InkJet Photo Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
2. Release RESUME
0 presses - green - Test print (or exit service mode on i960)
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
I turn on my playstation 3 it turns on for 2 seconds then turns itself off. the green light lights up then turns yellow before shutting off then the red light start flashing
What you got is the YLOD (Yellow Light Of Death)
And can be caused by overheating where the cpu/gpu may seperate from the board, in some cases it can also be a faulty psu.
my guess is that your cpu/gps is seperated from the board
And as i see it then you have 2 options :
1. if you still have warrenty i suggest you use it, and then send it to sony.
2. If no warrenty try this below, it does require tools, and some knowhow.
so be carefull if you wanna try this on your own.
ifyou dont feel like doing this on your own, then try search in google on"YLOD" and see if you can find any workshops near you, im sure thereis, since this is a commen problem now a days.
Part 1.
Part 2.
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
On and off lights
You have the yellow light of death. You will need to have the mother board serviced.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
OR
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
