Question about HP OfficeJet 7410 All-In-One InkJet Printer
Auto Duplexing lost with Vista drivers
Upgraded to Vista, dowloaded the HP Vista 32 bit drivers, and lo and behold...no more automatic duplexing.
I uninstalled and did it manually...same result.
Called 1800HPInvent....got a tech that told me ALL HP printers that have auto-duplexing lose the feature when Vista drivers are loaded. I even wrote to the president of HP and complained that for me, with a back injury, the duplexing was an accessibility issue...he foisted it off on some new MBA that had no clue what drivers or duplexing were.
Needless to say, I am underwhelmed with my experiences.
What a bunch of malarkey! Even if HP were waiting for a developers kit, Redmond sent the last of those out 3 or more months ago. Why can't the 'software wizards' at HP solve a problem that involves many existing customers. Not only might these customers not trust HP enough to purchase new printers from them, but they will then all the customers that fork over beuxcoup $$ for the ink cartridges will stop financing HP!
Anyway, does anyone here have a solution or other advice to get back the duplexing, other than uninstalling Vista (believe it or not, this machine is running as smoothly or better than it did under XP)
  • 1 more comment
  • PeninaD Jan 03, 2008
    Found a solution at VistaClues.com
    Resolve the issue of duplexing in vista using the following steps.
    a. Please open HP solution center click on Settings>> print settings>> printer settings
    * change the duplex printing settings to automatic in the solution center
    * Now click on Start>> control panel>> printers folder >> right click on printer icon and select printer properties
    * In the printer properties and in the advance option the duplex printing had a status not installed.
    * change the status to installed from not installed.
    * uncheck the manual duplex printing in the advanced Tab
    * Try printing.
    (This worked for me so far, so I did not try the rest.... but am leaving it here for anyone that it might help)
    b. Step-1
    1. Open the HP solution center . Click settings — print settings — printer settings.
    2. Click on the printing shorcuts tab .
    3. Select Automatic under the print both sides.
    4. Click on the Finishing tab and Enable the option ” Print on both the sides”
    5 Click OK .
    c. Steps -2
    1. Click the Start (Windows) icon, click Control Panel, click Hardware & Sounds, and then click Printers.
    2. Right Click on the printer icon and Select Properties.
    3. Click on the Device settings Tab.
    4. Under the Installable option - Duplex unit for two sided printing - Disable the Allow Manuall Duplexing.
    5. Click Ok.
    Here are the steps:
    1) Click Add Printer
    2) Select local printer
    3) Choose Port as LPT1
    4) Choose HP and then select HP Deskjet 6500
    After the driver is installed, perform below steps:
    1) Right click on HP Deskjet 6500 printer icon in Printers folder
    2) Click on Properties
    3) Click on Ports tab
    4) Click Add a port —> New Port —–> Select STANDARD TCP/IP PORT (HP Std TCP/IP port would be the one already selected) —>Enter the Ipaddress for the Std TCP/IP port, create a port.
    5) Click Apply and click Ok
    Now try to print.
    Close any application we are trying to Duplex from
    — Open the Properties for the driver and under the Finishing tab, select Print on Both Sides manually, and Preserve Layout. Leave all other driver settings default, and try printing from Wordpad first before printing from application
  • Anonymous Aug 02, 2008
    I'm unable to use auto duplexing with vista os and my offcejet 7410. Anyone have any suggestions?
  • farbeh Apr 18, 2009
    Duplexing printing is active but layout is changed from side bound to top bound. Cannot change this. Only deactivate.
    Novelist:
  • 79 Answers
The in-OS and the Full Feature release drivers for some of our products have a problem with doing duplex jobs.
Start a command window as an Administrator
Hit Windows Key (or CTRL and Esc Keys Together) Choose All ProgramsAccessories CMD Prompt – Right Click and Choose RUN AS ADMINISTRATOR When to prompt comes up click CONTINUE to allow the Command Prompt to run as an Administrator.
Stop the Spooler service - Type net stop spooler
Change current directory
Type cd %windir%\system32\spool\drivers\w32x86\3
Backup the old gpd files – Type copy hp*.gpd *.bak
Extract the files from the zip file to correct location
extract files to %windir%\system32\spool\drivers\w32x86\3 directory
Remove old BUD file Type - del HP*.bud file
Restart to spooler service - Type net start spooler
Print something duplex to test.
Thanks
Mac
Posted on May 27, 2008
6ya staff
SOURCE:
How to stop Automatic duplexer
Automatic duplexing is enabled either at the control panel or through the driver. Check the printer setup on the contorl panel under paper handling. If it is not turned on at the printer level then you need to adjust your driver preferences so it does not duplex all jobs.
Apr 02, 2015 | HP LaserJet P3005d Printer
I have a Kyocera FS-1920 printer. I can't turn on the duplexing in the application on my computer. Do I need a specific driver to enable duplexing?
Assuming that your printer has the optional DU-61 duplexer installed you may need to check and make sure that the print driver knows the duplex unit is installed. Go to printer properties, device settings and check near the bottom of the list for installed options and make sure that the duplexer is checked off.
Jan 10, 2015 | Kyocera Office Equipment & Supplies
Printing on both sides
Make sure the Automatic Duplexing option is enabled:
Enter Control Panel then Devices and Printers.
Right click the printer icon, then Printer Properties.
Click the Device Settings tab.
Set the Automatic Two-Sided Duplex Accessory as installed and click OK to save.
Now Automatic Duplexing should become available.
My LaserJet 1320 will no longer do duplex printing with Windows 8
Aug 07, 2014 | HP LaserJet 1320 Printer
I am trying to set the printer to automatic duplexing...?
Hi
If you want to set Print on Both Sides (duplex) as the default setting for all print jobs (even single page jobs) use the following steps.
  1. Click Start , Printers or Printers and Faxes from the Microsoft Windows desktop.
  2. Right-click the HP Color LaserJet 2605dn_2605dtn and select Printing Preferences (Properties in Microsoft Windows 2000).
  3. Click the Finishing tab.
  4. Select Print on Both Sides under the Document Options section.
  5. Click OK to save the setting and close the Printing Preferences window.
  6. Close the Printers or Printers and Faxes folder.
Note:In this scenario, all print jobs, even single print jobs, will be treated as Print on Both Sizes (automatic duplexing) for media that is supported by the duplexing unit. For media that is not supported by the duplexing unit, the job will be treated as Print on Both Sides (Manually) (manual duplex).
Jun 13, 2011 | HP LaserJet P4014n Printer
Can't print duplex on p2015d with pcl6 driver on windows 7 Only allows manual duplex with universal print driver pcl5 and pcl6
Hello, not all of the P2015 Series printers support Automatic Duplexing. Are you sure you have the correct model printer? Only the P2015D/DN/X support this feature. Check the front cover, it will have the model listed... In the printer driver, check the device settings, see if duplexing is an option and enable it.
Jan 15, 2011 | HP LaserJet P2015d Printer
Does the hp psc 750 do double sided printing
I have not used that specific printer, but from all I can determine, it is not a duplex printer. However hp offers these suggestions on how to determing if your printer is duplex: <br /> "To find out if your printer supports duplex printing, refer to your printer manual or look for the <b>Two-sided (Duplex printing)</b> or <b>Print on both sides</b> drop-down menu in the <b>Printer Properties</b> dialog box on your PC (sometimes found in the <b>Printer Shortcuts</b> tab).<br /> If you can
Aug 20, 2010 | HP PSC 750 All-In-One InkJet Printer
Is this a duplex machine please?
Yes it is.
HP LaserJet P3005n Printer (Q7814A)
Specs:
Duplex printing (printing on both sides of paper)
Yes: Automatic (standard)
Please give me a big thumbs up for my answer, when you rate it. Thanks.
Jan 28, 2010 | HP LaserJet P3005n Printer
LaserJet 5MPHP
Only if you print the first side then place the paper back into the printer to do the second side. Also referred to as manual duplexing. This printer has no automatic duplexing option.
Also keep in mind that the percentage of duplex prints you do should be very low as this printer has no method of cleaning the fusing unit as most printers do that are made for duplexing. The industry standard is 2% or less should be duplexed.
Jan 05, 2010 | Office Equipment & Supplies
Can only print one copy at a time
Download the latest driver from HP => http://www.hp.com/#Support
It's version 4.7 released on November 25, 2008. I recommend downloading PCL6 as it supports 1200dpi. PCL5 only supports 600dpi. Windows Vista comes installed with PCL5.
The driver took a while to install about 4-5 minutes on Vista 32 bit Home Edition. I thought I hung as mentioned above. I left to do something else and came back and it was finished.
I was having trouble with the HP1200 not manual duplexing and printing one page only. The new driver fixed the issue.
Nov 19, 2008 | HP LaserJet 1200 Printer
Getting the Duplex Attachment to Work with Vista
what printer do you have?
brand and model?
do you has installed the newest driver and utility for vista operating system?
do you know that Vista and XP are incompatible in terms of drivers?
Vista has many drivers for a lots of printers, but these drivers are "generic driver". The generic driver is a small driver, an incomplete driver, and has a limited functions.
Sep 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
249 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
