Home | Motorola | H700 Wireless Headset | Changed phones want to ...
Motorola H700 Wireless Headset
Problem for Motorola H700 Wireless Headset
Changed phones want to install blue tooth h700 but
By chicagoflp on Nov 02, 2009
changed phones want to install blue tooth h700 but it asks for a passkey. Where do I fibnd the passkey?
Best Solution
posted on Nov 02, 2009
Very Helpful)
hawk127311
Rank: Guru
Rating: 90%, 66 votes
The passkey is 0000 (four zeros). If you need instructions do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} First off, you want to have the H700 fully charged up and it's probably good to have the PHONE fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the PHONE.
On the PHONE, you want to push the "OK" button to get to your main tools area:
Choose Settings, then choose Connection:
Now you'll be able to pick which type of connection you want:
You want bluetooth, of course, so pick that:
Now you can specify that you want to add a new Handsfree device (even though, logically, you should go to Setup in my eyes):
Select Look For Devices, at which point the PHONE will scan for available units in the bluetooth frequency spectrum and hopefully find your H700 bluetooth headset. Assuming it does, it'll cheerily report the news:
If your PHONE doesn't find the headset, I suggest that you run the scan another time or two. Also make sure that the H700 is still showing purple, not blue or flashing blue. That should be all you need to do!
Once the PHONE has found the H700 unit, you need to actually pair them, so don't stop here. Select the H700 and you'll be asked if you want to bond the two units:
You want to say "YES", of course, at which point the PHONE will ask you for the bluetooth passkey of the H700, which, like all Motorola bluetooth headsets, is 0000. Enter it:
Choose "OK" to proceed to:
The phone has saved the pairing passkey, now it'll disconnect and search for it again in regular connection mode:
Hopefully it'll still find it, and verify the PIN:
Now, look at the H700. Notice it's no longer in the purple "pairing" mode but has switched to the regular slowly flashing blue mode. You're up, running. I hope this helps and Good luck!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Please remember to vote and leave a testimonial. Thanks.
Comments:
Nov 02, 2009
- Sorry about the code that is in the post. Just ignore it. Somehow copy and paste from MS Word is inserting code into the post.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Motorola H700 Wireless Headset
Questions and Unsolved Problems for Motorola H700 Wireless Headset
Do you recommend Motorola H700 Wireless Headset?
Answer
Answer
Im trying to program my headset and the password isn't working. Can you help me
Answer
how do i connect it to my phone i have a motorola bluetooth h 700 and a LG VX8100 phone
Answer
i have a motorola bluetooth H670....i can not remember how to answer a call or disconnect a... (More)
Answer
I can hear my contacts but they can't hear me. Is there a mute on an H715 motorola bluetooth? It... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motorola H700 Wireless Headset:
Top Headset Experts
Rank: Guru Guru
Solutions: 696
Experience: 30 Years of professional repair and design.
Ask Me
Find more Headset Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
