Question about Kodak EasyShare DX7440 Digital Camera
Kodak DX7440 Lens Cover does not open or close properly
I have owned my DX7440 for about 1-1/2 yrs & it has always worked perfectly for me. Fantastic Macro for the money. I use it quite often to take close ups of defects (cracks, corrosion, etc) while performing aviation maintenance inspections. I have always tried to be very careful to make sure that it does not get dirty, but I believe that I might have some dust or debris that is affecting the proper operation of the lens cover.
The cover is not completely opening or closing, when I turn the power on & off, & I have to gently coax it with a toothpick. I have tried to gently blow it with an aerosol type compressed air cleaner & have also tried to gently peck the side of the lens with a wooden pencil while the lens is extending & retracting, but nothing I have tried has solved my problem.
Any help or advise will be greatly appreciated.
Thanks
  • Anonymous Nov 22, 2008
    I have the same problem. Did you find a solution yet? I'm trying to find out whether my camera's lens can be dismantled!?
Thank you apr 22 guest! i got a fiberless cloth to place over the lense while i fiddled, first with my tweezers then with my plastic toothpick (from the swiss army knife! yay mcguyver!) and after fiddling a bunch with the top fan (which was partially exposed, and i thought wanted to come down) i simply stuck the toothpick in a groove where the bottom fan is stored and *click* is shut! turned on and off a few times and seems to be working like a dream again.
do be extra super mucho careful when fiddling around near the lense!!! when i say i was fiddling and poking around, i mean i was making double sure that the cloth was covering the lense then i was very patiently touching and tugging at only the fan/cover bits.
my lense is safe from dust again!!
Posted on May 17, 2010
Yeah, my ****-shell-like lense cover won't open or close properly. I thought I read somewhere the lens is removable!? If anybody found out how to correct the problem, let us know!
JK
Posted on Nov 22, 2008
It is a common, but in most cases intermittent problem with many cameras regardless of brand/model. I also own Kodak DX7440 since late 2004, and I had this problem twice, in 2007 and 2008. First suggestion: fully recharge the battery, it helped me the first time. Second: play with the lens cover, that is try to open/close it with the camera on/off. With me, in 5 min of these attempts, it suddenly fixed itself and stays this way for one month now. Another suggestion: dont use a toothpick, since it can scratch the lens. Use a q-tip, and to avoid cotton threads sticking to lens, wet the q-tip and let it dry.
Posted on Apr 22, 2008
Difficulty formatting new memory card for a Kodak Easy Share DX7440
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
Dec 01, 2011 | Kodak EasyShare DX7440 Digital Camera
Is the kodak dx7440 compatible with the sdhc cards?
Hi. Kodak DX7440 is using standard SD card or MMC card up to 1GB (some says it will read 2 to 4GB standard SD but I haven't tried). SDHC is high capacity, 4GB above and will not work on your camera.
Aug 19, 2010 | Kodak EasyShare DX7440 Digital Camera
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
Lens won't extend when switched on
I would like to know what mode are you clicking these photos in.. because overexposure is due to either slow shutter speeds or large aperture. Try setting the camre mode according to the surrounding light conditions.. for example, no need of flash when you are clicking pictures in broad day light, instead of setting the camera on Auto mode, try using Portrait mode for short distance (5 to 6 meters away) objects etc..
Let me know if that fixes the issue.
And important .. Do not forget to rate the solution :D
Thanka and Regards,
Srinivas
Apr 08, 2009 | Kodak EasyShare DX7440 Digital Camera
DX7440 messed up lens blurry distorted
You can only find out by opening the camera
Then you will not be able to get it repaired
Chances are it will not be repairable any way because of age.
So go for the New one.
Then open the old one - you get lucky you may just figure how to fix it - but dont hold your breath
Then if you are lucky you will have two cameras
Now beat that
Jun 03, 2008 | Kodak EasyShare DX7440 Digital Camera
DX7440 kodak cameras plastic battery lock broke off
I also have the same problem but it never worried me as when you close the outside battery lid it keeps the battery in place ok . I have a problem with the joystic operation on my dx7440 if any body has any suggestions
Feb 12, 2008 | Kodak EasyShare DX7440 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Kodak EasyShare DX7440 Digital Camera Logo
427 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
