Question about Mitsubishi PD-4265 42 in. Plasma Television
No Signal I have a PD-4265 Plasma TV, but when I turn it on I get "no signal" I can use the DVD player and it works fine, but it doesn't seem to be finding the signal with my Direct TV connection. I changed out the HDMI cable just in case but that didn't work. I have even tried all the channels (Monolink, Input 1, Input 2, Comp1, Comp 2, PC/RGB). I appreciate your time.
SOURCE: Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
Posted on Aug 05, 2007
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
  • 1153 Answers
SOURCE: No High-Def via monolink(HDMI) connection
Troubleshoot first by self diagnosis
Posted on Dec 16, 2007
  • 395 Answers
SOURCE: HDMI compatible?
yes the DVD player will work on it thru HDMI to DVI connector but however the audio is not carried on DVI so you will have to have a seperate audio cables. also the 1080p signal is not supported by this set 1080i only.
Posted on Jan 31, 2008
  • 301 Answers
SOURCE: no input selction for any inputs including hdmi
try pressing MENU 123 in sequence. this will reset the tv settings and make you start fresh.
Posted on Mar 29, 2008
Hi, We have a Panasonic Viera Plasma TV. The TV was on when all of a sudden we heard a few clicking noises and then the picture was lost and a 'no signal' message was displayed. We tried other channels...
It sounds like you have taken the steps to isolate the problem to the TV. it seems to be a bad tuner on the Main board. The no signal displayed indicates the TV is otherwise okay. If you have a DVD player or other source you can connect, and you get a picture, then your TV has a bad tuner for sure.
Feb 21, 2015 | Panasonic Televison & Video
The input dvd screen says no signal and the DVD player doesn't seem to have any power.
If it is in warranty return it---parts for the DVD unit are not available--they would have to replace the entire DVD unit inside the set.
Mar 12, 2012 | RCA 32LA30RQD TV
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
Jul 26, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
Plasma tv showing "Mode not supported" message
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Try with this,with the disc tray empty turn on the dvd then push for 5 seconds the button stop.If this don't work connect to the tv on the video signal the y connector you got signal on black in white but you can see the menu to deactivate this function.Good luck.
May 28, 2008 | Protron PD-800 DVD Player
Needing unlock code
sir,,,,the only solution for that is using a computer,,,,thnkss and hope too help you???
Feb 02, 2008 | Mitsubishi PD-4265 42 in. Plasma...
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
Mitsubishi PD-4265 42 in. Plasma Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
