Firstly , let me state that because I cannot see the camera or open it , my advice is extremely limited to my past experiences.
I suspect that the CCD/CMOS (the chip that physically captures light and creates the digital image) has broken.
If this is the case , a repair would cost approximately $100. This is the most common problem for a camera that takes distorted/black images but where the menu display functions and old photo's display normally.
Check to see if the video function works normally.If this does not work, it supports the idea that the chip has gone. Also see if photo's uploaded and again downloaded to and from the card looks normal. If these photo's are normal , its almost for sure you ccd.
I would take it in to a repair center for an evaluation , but would not have it repaired if the CCD has to be replaced as a new or refurbished camera would cost only slightly more.
Please feel free to contact me if you need further information
dropped 945 camera on lense with it on. Sounds like it broke track inside. Lense stays out. Can I...
(More)
dropped 945 camera on lense with it on. Sounds like it broke track inside. Lense stays out. Can I get parts?
LCD screen lights when turned on, green LED comes on briefly, then screen goes black. Lens will not...
(More)
LCD screen lights when turned on, green LED comes on briefly, then screen goes black. Lens will not retract
At start up, red focus light turns on & stays on, LCD dispaly goes on/off & camera...
(More)
At start up, red focus light turns on & stays on, LCD dispaly goes on/off & camera is ''locked up''. Only way to turn it off is remove the battereis. If connected up an ac adapter, camera starts up fine, with indication date/time needs resetting. Once camera starts, batteries indicate full charge (non-rechargeable Lithium), but rechargeables (NiMH) show up as non-rechargeable with about half-charge (the batteries acutal approximate state of charge) . If I disconnect ac adapter with the camera on, camera will work fine (its typical picture quality). Turn off camera & it won't restart again without connecting the ac adapter. Disconnecting the ac adapter and rmeoving batteries for more than 10 minutes to force a camera reset does not fix the problem Camera is 6+ years old. It passes all the camera self-tests.
