Question about Lexmark T630 Laser Printer
Lexmark t630 noise problem
In the last few months my printer is making a louder noise upon printing. It's a high frequency grinding type of noise. Thanks, Marvin
    Problem Solver:
  • 13 Answers
You printer may need a maintenance kit or the redrive replaced.
Posted on Feb 11, 2008
2004 dodge intrepid front end noise
Without a description of the noise, this is impossible to diagnose. Common problem with these vehicles is a "grinding" type noise. This will be a bearing that has gone bad or brake pads that are beyond the service life (louder screeching or grinding upon braking). Popping noises are the CV drive axles are bad (noise is typically louder when when the vehicle is in motion and turning).
Jan 31, 2014 | 2004 Dodge Intrepid
Lexmark t630 prints ink on right side of paper
there are typically a few causes of this.
1 - low toner
2 - charge and transfer rollers need to be replaced
3 - high voltage power supply is failing
the first 2 can be checked and fixed very easily
take the toner out and give the toner a shake and replace into the printer.
remove the toner, drop the front door down a couple inches and you will see the charge roller attached to the 2 arms drop down from the top of the printer in the toner bay. if the roller is yellow or orangish it needs to be replaced because the roller should be gray in color. hope this helps!
Feb 08, 2012 | Lexmark T630 Laser Printer
Making a clicking noise when it prints.
Here is a great guide that you can follow to try to identify where the noise is coming from and try to fix it or have it fix.
http://bit.ly/dif9Ck
Feb 06, 2010 | Lexmark T630 Laser Printer
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Hi, my name is Fernson I have a Lexmark t630 anytime i try to print something it says "load mp feeder letter "
Load "MP" means to load media into the Multi Purpose feeder , which is in the front of the printer.
This can be caused by several things, all of which are easy to fix.
First, open the printer driver and verify the correct selection of media draw.
Next, ujse the printer's paper menu to set the proper tray.
Lastly, make sure that the print file going to the printer is not asking for the MP Feeder.
May 07, 2009 | Lexmark T630 Laser Printer
T630 cannot print color
just a wild guess. it may not be capable of printing in color.
check if you indeed have color cartridges installed.
it says B/W - Black and White.
http://www.dooyoo.co.uk/laser-printer/lexmark-t630/
escription: Model ID 0010G0110 / Lexmark T630 - Printer - B/W - laser - Legal, A4, A4 Long - 1200 dpi x 1200 dpi - up to 35.1 ppm - capacity: 350 sheets - parallel, USB
Apr 28, 2008 | Lexmark T642 Laser Printer
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Lexmark T630 Laser Printer Logo
501 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
