Fuji FinePix S5000 Digital Camera
Problem for Fuji FinePix S5000 Digital Camera
Fault is black screen as if lens cap on . playback
By mkew_mprc on Nov 02, 2009
fault is black screen as if lens cap on . playback fine
Best Solution
posted on Nov 02, 2009
Very Helpful)
StephanSA
Rank: Guru  Cameras & Camcorders  Expert
Rating: 93%, 186 votes
Firstly , let me state that because I cannot see the camera or open it , my advice is extremely limited to my past experiences.
I suspect that the CCD/CMOS (the chip that physically captures light and creates the digital image) has broken.
If this is the case , a repair would cost approximately $100. This is the most common problem for a camera that takes distorted/black images but where the menu display functions and old photo's display normally.
Check to see if the video function works normally.If this does not work, it supports the idea that the chip has gone. Also see if photo's uploaded and again downloaded to and from the card looks normal. If these photo's are normal , its almost for sure you ccd.
I would take it in to a repair center for an evaluation , but would not have it repaired if the CCD has to be replaced as a new or refurbished camera would cost only slightly more.
Please feel free to contact me if you need further information
Kind regards
Stephan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Fuji FinePix S5000 Digital
Questions and Unsolved Problems for Fuji FinePix S5000 Digital
Do you recommend Fuji FinePix S5000 Digital Camera?
Answer
Answer
There is no image inside the display when I want to take a picture. And the same problem if I switch... (More)
Answer
when in photo mode it changes to preview mode...without changing switch
Answer
Hi when i turn the camera on it starts up comes up with the finepix on the screen then just switches... (More)
Answer
My battery door will not latch shut. The hold tabs are broken off. Is this fixable? Fuji Finepix... (More)
Answer
When turning on the camera to take a picture, many times there are horizontal lines in the view... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fuji FinePix S5000 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
