Home | AT&T | Blackberry Curve 8300 Smartphone | I have a blackberry cur...
AT&T Blackberry Curve 8300 Smartphone
Problem for AT&T Blackberry Curve 8300 Smartphone
I have a blackberry curve 8330 - was working fine
By tbarnes391 on Nov 02, 2009
i have a blackberry curve 8330 - was working fine - took battery out to re-boot - when i re-inserted battery, all i got was a battery symbol with a red line thru it. I cannot get the phone to connect to desktop manager, and cannot get my contacts out of this phone - any suggestions? i don't want to lose my contacts - too many to try and do manually
Comments:
Nov 02, 2009
- None of the battery contacts appear to be bent, and the battery is in right. I know it's not the battery itself as I have put another fully charged battery in the phone and no luck getting it to boot up - just get the same battery symbol with the red line thru it.
Nov 02, 2009
- Sorry - my first time on this site - I thought that the rating would just come back to you to let you know that the initial response would not work. Didn't mean it disrespectful at all. I appreciate you just responding - anything else that you can think of would be great.
Nov 02, 2009
- tried it - it did power off (the battery with the red line disappeared) - I took battery out and reinserted - it came back up with a battery that had a blue lightening bolt thru it now.
Nov 02, 2009
- i got it to work finally - apparently it was the battery connection - not sure why - I pushed the battery down hard on the pins, and got it to boot up long enough to backup the data on the phone. Thanks for all your help!!
Nov 02, 2009
Best Solution
posted on Nov 02, 2009
Very Helpful)
JackHeath
Rank: Guru
Rating: 85%, 213 votes
check that you did not bend the battery contacts and that the battery is right side in. You should not have to loose anything, the issue should be related to the position of the battery and it's contact with the pins at the top of the phone.
Comments:
Nov 02, 2009
- You should wait to rate the response until you're sure I can't find you the answer. You did not state that you had diagnosed the battery nor that the contacts appeared good. So I suggested you check those. Regardless, I will leave you to another technician and hopefully this information will help them diagnose your problem more accurately. I suggest however if you want to have assistance that you not rate the technician until you've allowed them the chance to work with you fully.
Nov 02, 2009
Try a soft reset by holding down Alt + Cap + Delete for about ten seconds. The device should power off. Remove the battery and then put it back in.
Nov 02, 2009
- Only thing I can find on a blue bolt is that the phone is using more power than the charger is charging. I would try plugging the phone directly into the wall, not through USB or car. If that doesn't work, and you can't reset it, you may end up having to wipe and reload the firmware which will also wipe the contacts. I'm sorry.
However, if you have ever updated your firmware...BB desktop backs up the device. You may actually have a backup already that can be restored. You could also sync to an Oulook contacts list which would keep you from having to enter each one in.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 03, 2009
Not Rated)
jaemeade
Rank: Apprentice
Rating: 0%, 0 votes
I have a problem with my voice volume. I am told by the people I talk with that my voice is normal and then it goes low and they are constantly asking me to repeat myself. What could be the problem? Is there any way this can be fixed?
Was this helpful?
Yes
No
Popular Solutions for AT&T Blackberry Curve 8300
Questions and Unsolved Problems for AT&T Blackberry Curve 8300
Do you recommend AT&T Blackberry Curve 8300 Smartphone?
Answer
Answer
red led is blinking and i cant tur on the telephone I already atake the battery off and still the... (More)
Answer
the sim to the old nextel blackberry wont work in the new nextel blackberry curve its to big for the... (More)
Answer
How do I get the open heart symbol on the bbm? And then how do I save it onto my phone?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AT&T Blackberry Curve 8300...:
Top PDA Experts
Rank: Guru Guru
Solutions: 551
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
