Sony Cyber-Shot DSC-W7 Digital Camera
Sony DSC W7 consumes battery in less than 5 minutes
shared by 17 users
posted by lroutaboul on Jan 03, 2008
My camera consumes a full charged pair of "AA" batteries in less than 5 minutes. I have tried with several batteries and chagers and the same happens.
Help me please!
Thanks.
Lisandro
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by doreendoreen on Apr 21, 2008
Thanks, but the battery door of my camera isn't cracked. Any other thoughts?
16 Other Users Have The Same Problem
Posted by smsorensen on Sep 27, 2008
Same problem for me. One picture with fully charged battery and it shuts off. Sony's only attempt at a solution is reset the camera, which does not work.
Posted by Guest on Sep 22, 2008
Had W5 for 2 yrs, upgraded to W7 2 more years. Sony batteries excellent, Duracelss OK. Panasonic rechargables kind of crappy, die quickly even after recent recharge, or recharged and left unused as spares, 3 days later when I try to use them, charge is gone. This happened before my battery cover started cracking. I don't think thats it. I stuck a piece of plastic across crack to strnghten overall battery door. Looks odd but works fin.
Posted by masonkw on Sep 12, 2008
I'm having the same problem except my camera shuts down immediately. I've checked the batteries with a tester and they are fully charged. The only thing I did differently before the problem was to get a larger card. I took it out and put the old one in and it is still having the problem.
Posted by Guest on Aug 10, 2008
same as others after several years of use
Posted by kakpui on Aug 04, 2008
Purchased in 2006
Did not have this problem esp with Video function
Sent to Sony Service Centre to complain loose contact of function dial.
They replaced dial but did not upload firmware.
Finally convinced them that they needed to upload firmware.
Initially the Sony AA batteries (2500 mHrs) WERE excellent -real lasting
Then I used Energiser AA 2500 mHrs. Initially OK, but then same problem
W7 just could not boot even when batteries fully charged.
Now my whole new set of Sanyo 2700 NiMh batteries just fail to power up
the Video function.
On review function it its OK ---battery indicator shows full charge.
Suspect it is firmware which somehow gives false reading to the camera
telling it the battery is flat !!!
Best Solution
posted on Jun 02, 2008
Helpful (85)
Rdkyl
Rank:Apprentice Apprentice
Rating: 88%, 5 votes
my battery cover is NOT cracked, and i am having the same issue...so possibly it is not just that. wish i could help, but i'min the same bind too! I have had mine for two years and it just started this stuff :-(
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sony DSC W7 consumes battery in less than 5 minutes:
I don't want to Accept this solution
Best Solution
posted on Oct 01, 2008
Helpful (85)
Pulsewave
Rating: 85%, 1 votes
Ok, gang, here is what I discovered with my DSC-W7. I initially started getting that camera message that said "please turn camera off then on". It always seemed to happen as I was zooming to the point where the optical zoom gives way to digital zoom for further reach. Sometimes the camera would just go black and the lens would freeze. I'd wait a while, then I could turn it on again. At first, I got my head wrapped around it being a camera logic or chipset problem. Checking the manual, I looked at the recalibration sequence, but that didn't seem to help. With my tech background, and knowing something about battery life and battery characteristics, however, I discovered the problem.
First of all, I was using NiMH rechargables, fairly new batteries. Better than ni-cad, of course, and they should have been fine. I've used NiMH for other gizmos. But I found, in measuring several sets of somewhat used batteries, that they were only reaching about 1.3 volts when fully charged. New AA batteries are 1.5 or even a little more. I surmised that the camera doesn't like working with batteries that are below optimum, and that it must have a fairly high threshold, or what we sometimes refer to when using battery backup systems as a "low voltage disconnect". In major systems, this saves big batteries from deep discharge. Anyway, I got some new, regular, non-rechargable alkaline cells, and also some AA lithium. Both indicated over 1.5. And the camera worked fine on those, even when I really did a lot of zooming, on-off cycles, etc. - to force the lens motors to work and load the batteries. No problems whatsoever.
So, you ask, in the previous scenario, why did the camera work again (if only briefly) after being turned off for a short time? Because batteries that are not completely or deeply discharged have a sort of bounce back characteristic. Just like a car battery that is low, when you try to start a car and it finally goes wow-wow-thud, and then you wait awhile you can crank the engine again somewhat. Same thing. In this case, there was just enough bounce back to bring the battery voltage back over the threshold so the camera would re-start, but shortly after that, under load, it crapped out again.
I have tossed out my NiMH batteries for this camera. Other cameras may have a different voltage threshold, but the W7 seems to be around 1.1 or 1.2 before it says 'I'm outta here'. Once I switched to AA lithium, even though they are throw-away, I get MANY more pics before they die.
This may not answer all W7 problems, but I'll bet it answers many of them in terms of weird behavior. Very likely power related.
Thank You!
Solution #3
posted on Sep 06, 2008
Not Rated (0)
camaro67892
Rating: 0%, 0 votes
I have a DSC-W7 cybershot, I use the factory charger with duracell 2650 batteries I can take pictures most of the day on one set of batts? Also use a 4G mem card. Battery life for me is excellent??
Thank You!
Solution #4
posted on Sep 02, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
try using energizer lithium batteries. Mine was doing that because I broke the charger to the batteries that came with it and I was trying to use regular batteries instead but it would take like 3 pictures and die. I finally figured out that the energizer lithium batteries work and they last a pretty long time.
Thank You!
Solution #5
posted on Jun 22, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Mine is fixed (new door). I took about 20 pictures one after the other and still full battery. So it seems to be fixed!
I take out the batteries now if unused for a longer time.
Stupid plastic doors...
Thank You!
Solution #6
posted on Apr 21, 2008
Not Rated (0)
Rhino77
Rating: 0%, 0 votes
So I had the same problem with my camera. The issue is related to the cracked camera door. The crack protrudes through the large C & E on the bottom of the camera door. When you close the door the negative battery doesn't fully contact the copper node that located on the battery door. The solution I reccomend is to buy a new camera door. If you need a quick fix I would take a small needle & pry up the copper node on the negative side of the battery door. This will allow more contact with the negative side of the battery when the door closes.
Thank You!
Solution #7
posted on Feb 20, 2008
Not Rated (0)
Captain Paul
Rating: 0%, 0 votes
Same problem for me. My battery door cracked and I assumed that was the source of the problem. Fully charged 2500 mAh batteries last 5 minutes max. .
Thank You!
Can you Help with these Digital Cameras problems?
I have a Cyber Shot DSC-W7. The Motor that extends the...
black blurred disc in same place in each photo with light...
Hello, My W7 went through a series of batteries in a...
The last few times I've used my DSC-W7 to take a video and...
my camera eates more battery, Fully charged 2500 mAh...
16 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 22, 2008
Comment by chris545, posted on Jun 15, 2008
Don't bother replacing the door. Mine is not cracked and eats batteries, so it is not that.
Comment by westy1, posted on May 03, 2008
Sony DSC W7 consumes new batteries and newly charged rechargable batteries in less than five minutes or two flash pictures. Camera is basically unusable.
Comment by Guest, posted on Apr 30, 2008
Same problem here, door cracked, battery lasts only a few minutes.
In fact, first I've noticed about the batteries, then found this topic, and then noticed about the cracked door :S
Comment by joonday, posted on Apr 17, 2008
Same problem as well batteries last all of 5 min. My battery door is also cracked.
Comment by PSPSPSPSPS, posted on Mar 30, 2008
I have the same problem with my DSC-W7 ...
It just eats up batteries and it doesn't matter what batteries I use.
My battery cover door is cracked. My brother has the same camera and his battery cover door is cracked exactly in the place and exact angle.
Comment by x6369x, posted on Mar 26, 2008
It just eats up batteries, even the regular Energizer Alkaline batteries.
The same batteries last forever in my DSC-W1.
I could also take a dead battery from the DSC-W7, and put it into the DSC-W1, and it would work fine.
Comment by hernandez07, posted on Mar 08, 2008
I have the same camera and mine is doing the same thing. My door is also cracked. Wonder if this is the problem?
Comment by GussyPoo, posted on Feb 09, 2008
Same problem here. Tried many different battery types and no luck. An estimate just to look at the camera for possible repair came in at $170. Does anyone know any ideas or at least a place to have it looked at for a reasonable price?
Thanks
Comment by doreendoreen, posted on Feb 04, 2008
My DSC-W7 (2005) goes through batteries in no time. We thought it was the rechargeable batteries and replaced them, but it didn't help. I'm trying to see if others have the same problem.
Comment by bhoman, posted on Jan 27, 2008
Same problem - brand new battery, or freshly charged lasts only about 5 minutes
Loading problems.
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
