I believe the warranty on the gearcase is actually 2 years. You can contact Whirlpool at 1-800-253-1301 to confirm.
If your washer is older than two years and you require a gearcase replacement, you can perform the repair yourself for about $150 if you wish to avoid purchasing a new washer. You can order the part on line at pcappliancerepair.com. The part number is 3360629. The following link explains step-by-step how to replace the gearcase if you wish to pursue the repair on your own:
NOTE: You can also order a refurbished gearcase at searspartsdirect.com for about $110. The part number is 3360629R.
This is not a difficult repair, but it can be time consuming if this is the first time you've attempted a repair like this. These machines are designed to easily affect repairs. Read through the link provided and let me know if you have any questions. I hope I've given you enough information to make your decision.
PS The quote you have is a bit high. Although the repair is still expensive, it usually runs about $300 if you have a repairman perform this job. Replacing a gearcase by a professional can be accomplished in less than an hour.
Have Whirlpool washer Mod LSQ9264HQ0 fills with water and stops. Won't go forward will add more...
(More)
Have Whirlpool washer Mod LSQ9264HQ0 fills with water and stops. Won't go forward will add more water but nothing else works. Have checked for broken belts, no belts. Has power in ,door switch has continuity. Thanks
water is in machine with clothes, agitated, now won't rinse.. when I put on rinse cycle is buzzes. ...
(More)
water is in machine with clothes, agitated, now won't rinse.. when I put on rinse cycle is buzzes. I unplugged to reset.. nothing...what is the problem? Is it worth repairing? 8 years old
washer agitates and is filled with water... will not do the rinse cycle, makes a buzzing sound when...
(More)
washer agitates and is filled with water... will not do the rinse cycle, makes a buzzing sound when I turn to rinse
